Oil Leaking..
Discussion in 'XJ Technical Chat' started by leondegrance, Jun 3, 2009.
  1. leondegrance
    leondegrance Member
    Saginaw, Michigan
    I have noticed that my front forks were leaking some oil at the rubber rings in the middle, where the shock absortion takes place.
    Should I be concerned??
    If so, what maintanance do I need to do..
  2. bill
    bill Active Member
    Raleigh, NC
    Replace the for seals. you are loosing for oil thorough the seals and it could become a safety issue over time as you loose more oil.
    It's not a hard job to do. There are several posts on the subject in the
    forums
  3. Pseudonym
    Pseudonym Member
    Bill,
    not criticizing or trying to offend, but is your 'k' broken on your keyboard??
  4. leondegrance
    leondegrance Member
    Saginaw, Michigan
    Thanks for the info...
  5. ktcubed
    ktcubed Member
    St. Augustine, FL
    Surely, nothing is broen on Bill. He just types so fast that his fingers miss some eys some times. When you answer as many posts as he does, you can't afford to eep going bac and checing all your posts for missing letters...
    kkkkkkkkkkk
    found them.
