What to replace on an old XJ bike
Discussion in 'XJ Technical Chat' started by hunterhicks, Jun 5, 2009.
  1. hunterhicks
    hunterhicks New Member
    D/FW TX
    Howdy all, been searching for problem & dangerous areas to look for on a bike that's been sitting for years. I've come up with these, do you have something to add?
    In my case, it's been garaged- just old.
    -rear brakes
    -throttle shaft seals
    -fork seals
    -front brakes
    -carbs..
    -replace gas/oil
    -tires
  2. 86xj700_indy
    86xj700_indy Member
    plugs and wires and driveshaft oil
  3. Robert
    In addition to both of your lists, I'll add replacing the fuse block.
  4. 86xj700_indy
    86xj700_indy Member
    maybe the fuses in the fuse block unless you can see that the box has dryrot
  5. SQLGuy
    SQLGuy Well-Known Member
    Are the plug wires on the 700's separately replaceable then? On the earlier bikes they're permanently attached to the coils.
  6. bill
    bill Active Member
    Raleigh, NC
    Check you brakes, fluid flush and especially the rear they can delaminate
  7. stereomind
    stereomind Active Member
    Tulsa, OK
    The stock fuse block wants to ruin your day! Kill it with fire before it strikes! :twisted:
    The problem is usually not dryrot. The clips that hold the fuses get corroded and brittle. You often can't see the corrosion, and the moment you try to bend the clips to make them fit tighter, they snap.
  8. 83xjturbo
    83xjturbo New Member
    this man speaks the truth. i used a small 6 fuse block from radio shack that takes atc fuses. very easy swap if your good with a soldering iron (i prefer to solder the wires on vs using push terminals)
