loss of spark when worm xj650
Discussion in 'XJ Technical Chat' started by mrlongshoreman, Jun 5, 2009.
  1. mrlongshoreman
    mrlongshoreman New Member
    Nova Scotia
    I lose spark on one coil once the bike is warmed up, tried different coil and same thing.
    Once I take the tank off ect to inspect wiring there is spark again.
    anyone have ideas where to start?
    thanks
  2. SQLGuy
    SQLGuy Well-Known Member
    That's going to be a tricky one. The only thing I can intially suggest is:
    At the TCI box, Swap Orange and Grey from the pickups, and swap Orange and Grey from the coils.
    This will allow you to run the bike with swapped channels in the TCI handling the two ignition banks. If you still lose spark on the same pair of plugs, then the problem is in the coil or pickup. If you lose spark on the other pair of plugs, then the problem is in the TCI.
  3. mrlongshoreman
    Nova Scotia
    Thats an excellent idea! and easy too!
    bc I tested the coils and pick up coils and suspect they are ok. wiring harness looks fine to.
    I was thinking about the TCI box and wondering how to eliminate it as a problem.
    I'll try it as soon as I can.
    Steve
  4. mrlongshoreman
    Nova Scotia
    ok this is embarassing ; I started switching wires got distracted now not sure which wire goes where
    does someone have a diagram off where the wires go? or picture? on the CDI
    thanks
