Choke cable question
Discussion in 'XJ Technical Chat' started by PopaGeorgio, Jun 16, 2009.
  1. PopaGeorgio
    PopaGeorgio New Member
    Wichita, KS
    I just bought this bike 1986 xj700. I notice where the choke cable connection is supposed to hook to but there is nothing to mount the cable in the location so it will flop out eventually. If anyone has this model of bike or knows this choke issue that i speak of please enlighten me.
  2. bill
    bill Active Member
    Raleigh, NC
    At the handle bar or the engine side?
  3. PopaGeorgio
    Wichita, KS
    At the carbs is what i was wondering about. because i notice there is a nice rack like insert for the accelerator cable. then the choke has a off set v at the cable connection... but nothing to mount the cable its self.
  4. bill
    bill Active Member
    Raleigh, NC
    It should clamp at the carbs....
  5. PopaGeorgio
    Wichita, KS
    i might have to send you guys a picture because this shit does not make sense=) i must be missing something. unless im supposed to bend metal that looks like it has never been bent before =)
  6. typo
    typo New Member
    If it's that clip/holder near the carbs, it's not really necessary, it's just a convenience. I got an XJ550 without that clip and I basically hold down the choke with my finger to get it started. I'd love to get the little clip for it, but I've never needed it.
  7. bigfitz52
    The clamp at the carb side is just a screw through a slightly bent little square bit, that screws to the bracket; at least on the 550s.
    You can see the cable and clamp in this pic, nestled in the red rag.
  8. bill
    bill Active Member
    Raleigh, NC
    Should look like Fitz's pic on your bike too just in a different spot on the carbs...
  9. PopaGeorgio
    Wichita, KS
    My choke hookup is between carb 3-4 if your sitting on the bike counting left to right. i was busy last night finishing stuff up on the bike but tonight i will submit pics for ya.
  10. bill
    bill Active Member
    Raleigh, NC
    Yup your carbs are different from the ones pictured but the choke clamp looks the same.
  11. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    I've got the same setup. I'll go out and take a pic. I know what you're talkin about. Gimmie a min
  12. SLKid
    SLKid Active Member
    Sorry it took so long! Had to help gfs mom move some stuff. Ok here you go
  13. PopaGeorgio
    Wichita, KS
    i can tell now that my choke lever is mounted upside down on the rack and they neglected to put the mounting bracket for the cable back on the top of the carb on my bike. This is what happens when you buy a bike from a guy that moved here from India and takes his bike to the cheapest place in town to get worked on.
  14. SLKid
    SLKid Active Member
    lol, sooo sowwy. One of those should be easy to make
  15. chacal
    And depending on which bike you need this bracket for, I may have some good used ones available.......if it's for the XJ700, I need to know whether your engine is air-cooled or water-cooled.
