Question about the headlight or aux headlight turning on!
Discussion in 'XJ Technical Chat' started by ghr4new, Jun 18, 2009.
  1. ghr4new
    ghr4new New Member
    Ok, I've just about pulled all of my hair trying to figure this one out..Its on an '82 - XJ750RJ that has the square headlight as well as a square aux headlight. My question is; since I haven't driven this bike in such a long time that I forgot..Do these headlights only come on after the motor starts running, or is the headlight supposed to turn on when you turn the ignition key "on" and the same for the aux light after you flip the handlebar switch to the on position? FYI Still working on getting the engine running, it turns but doesn't start. That's another problem, but I'm taking it one step at a time and trying to solve this headlight issue 1st.
    Thanks,
    George
  2. kc0jov
    kc0jov New Member
    Saint Louis, MO
    Re: Healight or aux headlight go on
    On my 81 550 Maxim (with the single round headlight), the engine has to start (or almost start) for the headlight to turn on. Not sure, but the 750 is probably the same deal.
  3. SQLGuy
    SQLGuy Well-Known Member
    Re: Question about the headlight or aux headlight turning on
    Just checked mine; neither light comes on until the bike has been started.
    Cheers,
    Paul
  4. ghr4new
    ghr4new New Member
    Thank you all! Funny how we take things for granted until they stop working. Now on to my next battle and beyond!
    George
  5. KVB_650
    KVB_650 Member
    Quebec
    I am having strange thing with my 750 Seca, when I turn on the key the lights come on, when I start the bike, the lights go out.
    Any ideas?
    Ken
  6. Ltdave
    Ltdave Member
    have you been in the headlight bucket lately?
    im thinking theres a wire or two crossed up somehow. or maybe a switch thats in need of cleaning or adjustment...
  7. Polock
    mine comes on with the key then off when the starter button is pushed then on when the motor starts
  8. gregu
    gregu Member
    Solvang, CA
    Guys
    I was baffled by the same problems. Yamaha service manual (the written portion) actually says that the light comes on when key is on. However, the wiring schematic shows power to the headlight relay (coil side) comes from the AC generator; therefore, the motor needs to turn which powers the coil which then closes the relay for power to the light. There is a diode (in headlight bucket) for the circuit that is easily checked for continuity. And that's about it.
    Hope that helps.
  9. NursePadawan
    NursePadawan Member
    Lansing, MI
    On mine, the main headlight comes on when the key is turned to "on". The smaller aux. light comes on when the key is turned to "on" and I flip the little switch below the engine cut-off switch.
  10. KVB_650
    KVB_650 Member
    Quebec
    I had the wrong relay in place, blue when it should hve been yellow, thanks Chacal, up and running now.
    Up next: replace the master brake cylinder with something a bit more convient.
