Special Tools
Discussion in 'Hangout Lounge' started by efigalaxie, Jul 4, 2009.
  1. efigalaxie
    efigalaxie New Member
    Salem, VA
    I have been reading and have notice that here and there, a special tool is needed for a procedure. I have a good assortment of metric tools. What are the most needed special tools??
    Also,
    The PO gave me the Haynes manual with the bike (82 xj650) What other tech docs would be adviseable?
    Thanks - David
  2. johntc
    johntc Member
    South Dakota
    Personally I prefer the Clymer manuals. They still don't cover everything but in my experience they don't leave as much out as the Haynes.
  3. RickCoMatic
    Not in any particular order:
    The YICS Passage Blanking tool
    Manometer
    Vacuum Gauge
    Compression Tester
    Elect. Multi-Meter
    ColorTune Spark Plug Set
    Valve Shim Exchange Tool
    Torque Wrench ➜ Foot Pounds
    Torque Wrench ➜ Inch Pounds
    Metric Allen Sockets
    Hand-Held Impact Driver
    To name a few, ...
  4. efigalaxie
    Salem, VA
    The YICS Passage Blanking tool - Where is the best place (cheapest)to get this??
    Manometer - Don't have - Recommendations??
    Vacuum Gauge - Got it
    Compression Tester - Got it
    Elect. Multi-Meter - Have several.
    ColorTune Spark Plug Set - Where to get??
    Valve Shim Exchange Tool - Where to get??
    Torque Wrench ➜ Foot Pounds - Got it
    Torque Wrench ➜ Inch Pounds - Got it
    Metric Allen Sockets - Have wrenches - will have to get sockets
    Hand-Held Impact Driver - Are we talking about the one you strike w/ a hammer?
  5. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    You can get everything your looking for from Chacal, Just PM him.
    The Metric allen sockets sure make it fast and easy. You can usually pick up a cheap set at HarborFreight.
    And Yes, the hand impact you strike with a hammer.
  6. Polock
    this is a allen wrench or key, never heard of a allen socket
    a slip of the keys i would imagine
  7. wizard
    I know what he means, Mr P, they are allen keys that fit on your socket wrenches, I have them.
  8. Polock
    i always called those allen drivers ?
    but what we call pop you probably call soda :)
  9. bigfitz52
    one of my personal favorites:
    The RickCoMatic patented hammer handle pry bar. Get a replacement hammer handle from the hardware store, and saw off the slotted part where the head is supposed to go on. Smooth off the edges, and you have a very handy tool for:
    prying loose a rack o'carbs;
    popping off a stuck valve cover;
    separating your rear wheel from the final drive;
    and any other prying/wedging that requires strength from a non-marring tool. I actually have two, a big one and a smaller one.
    and:
    KROIL. http://www.kanolabs.com/google/ No mechanic's tool kit is complete without it. It honestly and truly makes all other penetrants obsolete. It will work when all others fail. You NEED this stuff to work on an XJ.
  10. bigfitz52
    OOPS, missed the second part of your question.
    Haynes manual ok; I have a Clymer for my 550s and IT also leaves a lot to be desired.
    Find a factory service manual. chacal offers reprints I do believe, or you can troll eBay they pop up all the time. I got my 550 factory book for $15, complete with grubby fingerprints and coffee stains.
    Don't get me wrong; the factory books leave stuff out too. The combination of the factory book and a Haynes or Clymer is the best way to go. Plus this site.
    You can also order the XJCD but unless you print it out or have a PC in your shop it's inconvenient (for me anyway.) Lots of good info on it though.
  11. TIMEtoRIDE
    Valve Shim Exchange tool- - 6 inches of 12/2 electrical with the last 5/8 inch bent over, stuck thru the plug hole, then above the valve.
    Manometer- - Make a water filled 4 tube (trust me :wink: )
    http://www.xjbikes.com/Forums/viewtopic ... rt=15.html
    Don't forget the restrictors.
  12. ktcubed
    ktcubed Member
    St. Augustine, FL
    IF the 82 650 is an RJ (seca) he doesn't need the YICS blanking tool as that is a non-YICS engine.
  13. efigalaxie
    Salem, VA
    No, it is an 82 xj650 Maxim. YICS right there in print on the motor.
    I tabulated all the tools I wanted for just the fuel section off of XJForever.......$606.00 - More than I paid for the two bikes!!!AAAARRRRRRGGGGHHHHH!! I wonder how much he would discount if I ordered it all at once.........
  14. ktcubed
    ktcubed Member
    St. Augustine, FL
    He'd probably give you free shipping :)
