YICS with a twist
Discussion in 'XJ Technical Chat' started by wizard, Jul 4, 2009.
  1. wizard
    Here's my version of the YICS blank off tool, main difference is the threaded plug & the use of only 3 expanding rubber collets.
    The tool is inserted into the YICS chamber & the threaded plug screwed in, then the 'handle' on the rod is turned CCW which expands the collets.
    Very quick & easy to use.
    The rubber is vac' pipe & has been tested with the blow torch, it does not ignite, but will only become hard under the flame.
  2. Polock
    HaHaHa THEY GOT TO YOU HohoHo
  3. wizard
    How can I prove it ain't neccessary if I ain't got one to compare.
    I know what it looks like, Mr P. :oops:
  4. bigfitz52
    So turning the handle tightens the nut at the other end causing the expansion? What holds the nut or does just the "bind" from the whole assembly provide enough drag?
    I LIKE it. The vac line holds up to a torch, but how about direct contact with really hot aluminum? Automotive vacuum line from the local parts counter I assume?
    Have you actually tried it yet on a hot motor?
  5. ethanch
    ethanch Member
    Spokane, WA
    yeah, you should try rolling the vac line around on mama's aluminum skillet for a minute after you have heated it up to 4 or 5 hundred degrees
  6. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Wiz, I'm very excited about this. I did not know you'd go THIS far to find an answer. But if you dont do it, who will? I'm very interested in your verdict when all your testing and stuff is completed.
    With respect mahn
    -Chris
  7. ethanch
    ethanch Member
    Spokane, WA
    I will be following this topic as well.I am also intrested in the final outcome,
  8. wizard
    The end of the threaded rod is tripple lock nutted, so turning the rod CCW tightens the whole assembly & compresses the rubber in the normal way. Don't forget the plug is threaded through it's centre.
    I havn't tried it on a hot motor, my 650 is pre YICS. but it is a simple job to change out those rubbers if something better comes along.
  9. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    It looks like he has it threaded into the bolt that threads into the port. Thats why he only needed 3 block-offs. Turning it counter-clockwise would tighten it up in the port.
    Nice job Wiz! And Quicker than I !
  10. bigfitz52
    Oh, got it; didn't realize the plug was threaded thought the rod was a slip-fit. Makes sense now.
