Oil Light Problems
Discussion in 'XJ Technical Chat' started by LAN_MAN, Jul 6, 2009.
  1. LAN_MAN
    LAN_MAN New Member
    Michigan
    About a week ago the oil light stop turn on when the engine stopped on my xj650.
    The only time I see it now is when the starter is engaged
    This bring up a few question
    1. where is the oil sensor/wire
    2. where is the oil sensor Circuit
    3. Where should I start and what order should I test in
  2. Thijs_205_Rallye
    Thijs_205_Rallye Member
    Somewhere in the Netherlands
    Yamaha's have an oil level switch instead of a oil pressure switch.
    It is normal that it lights up while you're starting the bike, that is a sort of check if the bulb still is ok. (the fuel light should light up also while cranking)
    grz Thijs
