headlight bucket
Discussion in 'Hangout Lounge' started by jay1, Jul 16, 2009.
  1. jay1
    jay1 New Member
    hello people a quick question i have a 1983 yamaha xs 400 maxim i want to put a chrome headlight bucket of a 1983 yamaha xj 750 on my bike the reason why is that mine is black and the xj 750 iss chrome both lights are 7 inches will it work?
  2. bill
    bill Active Member
    Raleigh, NC
    Welcome Jay - It should work fine. The round buckets are mostly the same. I am rehabbing an XS400 (82) I kind of like the black bucket. Let me know if you get rid of your old bucket, I could use one in good shape, mine is OK but not great.
  3. bigfitz52
    Be careful; they may LOOK the same but due to different contours, depths and shapes, the distance between the mounting holes (side-to-side) CAN be different sometimes, depending on year and model. The best bet is simply to measure. That distance (the space between the ears) is really the only limiting factor.
  4. Shannon72
    Shannon72 Member
    Wisconsin
    Not to thread hijack, but I NEED this on a t-shirt.
  5. jay1
    jay1 New Member
  6. chacal
    There's also the LOCATION of the lower pivot bracket mounting point that differs between most of the Yamaha headlight buckets.....some are on the right of center, some are left of center, some are way up front (where the outer bezel/rim attaches), some are way towards the back...........
  7. bill
    bill Active Member
    Raleigh, NC
    Wow I stand corrected - I never noticed those differences. The ones I have dealt with have been the same or close enough that I didn't notice.
  8. bill
    bill Active Member
    Raleigh, NC
    Given the bucket includes the mount a lot of the differences mentioned are negated. Here is a problem I see - if the 83 XS is like the 82 the instrument cluster mounting bolts are attached to the cluster and go through the headlight bracket and are attached with nuts.
    On my 650 and on this bucket the cluster mounting bolts are separate and screw in to the headlight bracket. You many have to do some mods to make it work.
