Petcock Vacuum Valve Leak-by -- THE FIX -- by: RickCoMatic
Discussion in 'XJ Technical Chat' started by RickCoMatic, Aug 21, 2006.
  1. RickCoMatic
    Everybody with that "Vacuum valve leak-by" ... Do this for THE FIX!
    Pull the Vacuum valve off the petcock.
    Using a 19mm socket as "The Table" and a Standard Small "C-clamp" as the Press ... PRESS the Center Spring Retaining Rod- ON THE ALUMINUM DISC SIDE -- IN ... .015 - .020mm Causing the aluminum disc to form a slightly concaved surface ... thereby moving the opposite side of that rod ... where the O-ring attaches ... to be moved .015 - .020mm further into the recieving taper of the valves O-ring seat. FIXED! DONE.
    This is "The Fix" ... for "Petcock Leak-by"
    Just another in the long list of inovations brought to you by the World Leader in XJ-Series restoration techniques and shop tricks.
    RickCoMatic ... They don't call me "RickCoMatic" for 'nuthin!
    'Cuz wenn dat boa gots iz mo-jo woikin' ... yeh jess no sumpin' good gunna appin' ...
    Kin ah gits ah Hey-men on DAT!
    I fixed it ...
    Copyright Aug 21 2006
    Richard E Massey
    Billerica, MA
    The RickCoMatic Leak Fix
  2. Robert
    Alayluya brother and pass the peanut butter please! Glad your out there Rick. Pity I don't have an X to enjoy the fruits of your labor with. Someday...
  3. richard03
    richard03 Member
    Texas
    Re: Petcock Vacuum Valve Leak-by -- THE FIX -- by: RickCoMat
    Thanks Rick. I just used this yesterday, and it worked! So again, thanks!
    Now for my rant:
    Stupid K&L! How can several parts out of a kit not work right?
