help with lights please
Discussion in 'XJ Technical Chat' started by midnightmaxim13, Jul 24, 2009.
  1. midnightmaxim13
    midnightmaxim13 Member
    i just got an 81' midnight maxim 650 and when i got it there were alot of issues with the lights, ive got all but two working now but i need help.
    first and most importantly my front brake doesnt turn on the brake light. where is that switch or how does that work so i can have an idea on how to fix it? secondly my neutral light doesnt work it doesnt really matter but its the only light on my bike that still doesnt work so any ideas for that?
  2. RickCoMatic
  3. midnightmaxim13
    i know for a fact the bulbs work the brake light lights up when i use the rear brake but not with the front brake.
  4. 650boy
    650boy Member
    AB, City Of Champions
    its the switch make sure you clean the moth balls inside and just give it a little clean with a light grite sand paper...
  5. midnightmaxim13
    wheres the switch at? i feel kinda stupid asking but this is my first bike and i only got it a couple days ago.
  6. wizard
    At the brake lever / perch you will see a pair of wires covered in black plastic, look underneath & you will see a tiny hole, push a small nail punch in there & at the same time gently pull out the switch.
  7. midnightmaxim13
    thanks man the switch was just a little screwed up so i just fixed the switch and now my brake lights work
