what brand oil
Discussion in 'XJ Technical Chat' started by xj650t, Feb 16, 2009.
  1. xj650t
    xj650t New Member
    south boardman, Michigan
    Ok I don't know what kind of oil to use for my bike xj650 turbo
    And what kind to use for the driveshaft.
    So I would like to know what you guys would use
    As far as brand and waight
    And why you would use that kind
    O yeah it's got 20,000+ miles
  2. caniculaveritas
    caniculaveritas Member
    SE Michigan
    I've had really good results running Rotella diesel oil.... I believe its 5-40w but I've only seen it in one weight so double check that. Plus it's cheap and doesn't contain anything that will mess with the clutch afaik. I ran the synthetic version because I split some with a friend on one oil change and my clutch started acting up so I switched back and its been grand ever since.
    My friend runs it on his new street triple and put almost 10k miles on his bike last year and the oil analysis came back excellent fwiw.
  3. bigfitz52
    I wouldn't use 5W-anything in an XJ when it calls for 20W or 10W...
  4. caniculaveritas
    SE Michigan
    my bad fitz, i meant 15-40
  5. jamings67
    jamings67 Member
    CT USA
    I used the same oil in my new xj 1100 and I could here a knocking that did not sound rite when the bike was warm. I did some research and found out that GTX 20w50 was the best in petroleum based oils as far as viscosity breakdown under the kinds of heat that air cooled inline fours make.
    I change the 15-40 out for the GTX 20-50 and the engine sounds normal when hot. I used the ROTELLA 15-40 in my other bikes with good results, But not in my Yamaha. Just a heads up.
  6. xjmannen
    xjmannen New Member
    can this oil work in a xj 550
    volvo penta oil
    can it harm my bike i can buy it verry cheap so i can change it more often if needed
  7. XJbull81
    XJbull81 Member
    Indiana, USA
    I wouldnt use it, just for one reason it is synthetic , another reason, I read on here that non MC oil for cars has stuff taken out of it that MC's need.
    I guess you could say you get what you pay for.... :)
  8. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Castrol 4T. Designed specifically for 4 stroke motorcycles and is designed to hold up under the extreme heat loads of air cooled engines. They are able to leave zinc and one other additive in place while they had to remove them from their automotive oils to meet federal pollution guidelines.
    It is available in 10W40 and 20W50 weights. I use 20W50 in both my BMWLT because it meets BMW's specs and my also in my Maxim as protection against heat breakdown. It's interesting that then LT is a water pumper and BMW still calls for 20W50.
    It's also readily available at auto parts stores and is reasonably inexpensive at about $4 a quart.
    Loren
  9. Hack
    Hack Member
    Ontario, Canada
    I use Castrol 4 stroke motorcycle oil. 20 W 50 weight. Available at Wally-World.
  10. xjmannen
    xjmannen New Member
    the volvo penta oil cost maybe 23dollar for 1L in stores and i can buy it for 4dollars so it is not a cheap oil. i have it in the bike right now but havent driven it much.
  11. wamaxim
    Vancouver, USA
    sjmannen,
    This is really quite simple. I am at work now so can't check my factory manual for the correct designation oil but I'm sure someone will chime in soon.
    It really doesn't matter which oil you use as long as it meets the service designation for the Maxim. The Volvo Penta oil is for water cooled marine applications, yes? It may or may not meet the service requirements for an air cooled motorcycle but if it does and you have a source? No problem. Use it.
    Saving a buck or two by using an incorrect API service level oil may prove to be false economy in the mid/long run if it can't handle the heat and loads for your bike.
    Loren
  12. xjmannen
    xjmannen New Member
    if i read it right regular engine oil is ok or 4t oil
    SE oil is a old oil that is not 4 sale anymore if i understand it right
