Carbs off - sprinkelers on
Discussion in 'XJ Technical Chat' started by maxhog650, Aug 23, 2009.
  1. maxhog650
    maxhog650 Member
    Boulder, Colorado
    :x :x :x dammit. I could tell you the long story but its not that interesting. theres some water in the engine. maybe a tiny bit maybe a lot. what do i DO! I was just about to have it running magnificantly too. Is this a big problem?
  2. helmet
    helmet Member
    depends on the amount of water. if it isnt much (drops) it wont be a problem. larger amounts can cause a problem simply because it doesnt "squeeze" like fuel does under compression.
  3. Polock
    tank ? crankcase? carbs? air filter box?
  4. Broke_Dirty_Maxim
    Broke_Dirty_Maxim Member
    Jacksonville, NC
    Pull the plugs and crank the engine a for a few seconds. Perform an oil change. End of problem.
  5. turtlemann14
    turtlemann14 Member
    drain the float bowels drain the water out of the engine before cranking
    (oil floats water sinks it will be on the bottom near the drain plug, until you crank it)
  6. maxhog650
    maxhog650 Member
    Boulder, Colorado
    Thanks, I guess its not as big of a deal as i assumed. Problem will be solved when im home from work
  7. dawsoner
    dawsoner Member
    Boulder, Colorado
    It runs now!!!! And clearly labels you a Steelers fan. I think you owe the forum a picture max...a before and after if you have a before....
  8. maxhog650
    maxhog650 Member
    Boulder, Colorado
    Alright ryan, I think I have a before, and after will come once the pvc intake is painted
