no rear running lights
Discussion in 'XJ Technical Chat' started by marine87, Aug 25, 2009.
  1. marine87
    marine87 New Member
    k another problem I just noticed on my xj600s seca II. When the bike is on the headlight turns on and works just fine. If I press on the brake or use either turn signal those work, signal on front and back, brake on back. however when the bike is just on(not pressing on the break etc...) I have not running lights on the back like I would need when riding at night. No clue what the problem is???? any suggestions???
  2. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Have you checked the bulb?
  3. Altus
    Altus Active Member
    London, Ontario
    If you mean running lights as in the turn signals - they should not be on - there are no running lights in them.
    If you mean the tail light running light - then yes - I'd say check the bulb and/or the connectors going to it.
  4. marine87
    marine87 New Member
    thanks duh just needed a new bulb....with all the other problems I guess i'm not thinking straight when something easy to fix gets added to the mix. Again thanks for the input
