Rear Signal Wire Routing - 84 XJ750 Maxim
Discussion in 'XJ Technical Chat' started by hydronaut, Aug 26, 2009.
  1. hydronaut
    hydronaut Member
    Newmarket, Ontario, Canada
    Hi, hopefully somebody can help me out. Previous owner must have replaced the signal wiring and has it hanging loose from the back under the seat.
    I am planning on replacing the wiring but want to know how to route it. Should they go through the same grommet as the taillight wires?
    Andrew
  2. hydronaut
    hydronaut Member
    Re: Rear Signal Wire Routing
    Anybody mind snapping a quick pictures or taking a look?
    Andrew
  3. Broke_Dirty_Maxim
    Broke_Dirty_Maxim Member
    Jacksonville, NC
    You can route the wires any way you want, just make sure they aren't going to get pinched when you have everything put together.
  4. hydronaut
    hydronaut Member
    Thanks,
    I was just curious how they were originally.
    Andrew
  5. hydronaut
    hydronaut Member
    Any chance anybody has a pic or description how the wires were routed from the factory? The rear signal wires seem to be the only mess.
    Andrew
