Petcock - Fuel line ok, where does the vacuum line go?
Discussion in 'XJ Technical Chat' started by mikegustus, Aug 29, 2009.
  1. mikegustus
    mikegustus Member
    Los Angeles
    I gungho'd it to replace a the larger (fuel) line and didn't didn't pay attention to where the smaller tube went?
    No manual here, I rely on internet. Thanks in advance!
  2. moellear
    moellear Member
    Lima, Ohio
    should slide right over a needle on any carb to engine boot. the tube is connected on any of these to allow suction and only operate the fuel when engine is running
  3. wizard
    Normally #3 boot.
  4. joshua
    joshua Member
    Lake Worth
    #3 boot is correct and ALL o them go there on stock bikes. for 10 bucks u can obtain a CD. check the forum for the guy that has it. everyoine knows bout him and i forgot his monicker
  5. bigfitz52
    Well, almost all. The 550s go to the #2 manifold.
  6. mikegustus
    mikegustus Member
    Los Angeles
    thanks!
  7. schmuckaholic
    California
    You're thinking of the XJCD. (It's actually three CDs, but who's counting?) In the US, that would be Brad Bowen. Duane Verhey in Canada.
    Or, you could just go HERE and order it.
    ...and the Maxim-X.
