fuse blows
Discussion in 'Hangout Lounge' started by johnboy_28, Sep 14, 2006.
  1. johnboy_28
    johnboy_28 New Member
    camden,australia
    hi all
    just a quick question i am trying to reset up my turn signals which were stuffed up by the previous owner have found the right indicator wire but the one that it says is the left wire(brown) keeps blowing the fuse and i did notice the neutral switch was flashing before it popped any help would be great
    thanks john
  2. RickCoMatic
    Neutral light is FLASHING!
    Signal light should be the one flashing.
    UN-plug the wire feeding the Neutral Switch and plug-in the signal light to that wire.
    Place bike in Neutral ... Ignition switch ON.
    Test other wires for 12V ON with bike in Neutral and OFF when any gear is selected.
    That's the one that should be powering the Green Light.
    OK?
  3. johnboy_28
    camden,australia
    Re: fuse blows fixed
    hi all
    the fuse problem is fixed now because the blinkers i was using were not original they had two wires the coloured one was the earth and black was active ah i think that make me the stupid one well all done now .now on with the show
    john :roll:
