Oil Recommendation for 1985 XJ Maxim X
Discussion in 'XJ Technical Chat' started by mpeels, Sep 20, 2006.
  1. mpeels
    mpeels New Member
    Tennessee
    I am a new XJ owner and would like a recommendation on a brand and type of oil to use in my 85 Maxim X. Is synthetic the way to go and if so which brands would you recommend. Thanks.
  2. Joel07
    Joel07 Member
    Durham, NC, USA
    Go with motorcycle-specific oil, it doesn't have the friction modifiers that car oil do. The car oil can make the wet clutches slip. I just picked some up at Advance Auto, it's Valvoline motorcycle-specific 10W-40. At $3.88 a quart, it ain't cheap, but at least I know it's right.
  3. Steve
    Steve New Member
    Nashville
    I've used 20/50 Valvoline for over 10 years with no problem, once winter hits I will drop to a lower viscosity.
    80 XJ650G
    05 YFM660
  4. RickCoMatic
    I'm a Castrol 20/50-Man.
    I'd endorse Castrol's racing blend without hesitation. I dump it every 25-hundred to three thousand miles for a nice fresh load. The bikes seem to love it.
    I still have great compression on the 900 after 65,000 miles. I need it in the 750 Max, because she and I have been scortching the blacktop shortly after getting the license plate bolted-on, earlier this seson.
    I have really been leaning-on-it some. With the 20/50 protection; I know everything turning at high speeds is being lubed nice and the level in the sight glass isn't about to deminish when it's been run hard and heated-up good.
