backfiring...now bike is stalling and not starting for 10min
Discussion in 'XJ Technical Chat' started by chadall3n, Sep 5, 2009.
  1. chadall3n
    chadall3n Member
    Clinton, MA
    my bike seems to be running well since i cleaned out the carbs about a week ago. However it backfires here and there primarily in the lower gears and when i downshift. I was just wondering if this is normal or do i need to adjust something?
  2. helmet
    helmet Member
    Re: backfiring
    like popping through the exhaust as you are engine-braking or as you are just cruising?
    stock exhaust?
  3. leadboots
    leadboots Member
    aylmer ontario canada
    Re: backfiring
    what does your plugs look like?
  4. SQLGuy
    SQLGuy Well-Known Member
    Re: backfiring
    Same question as the others: backfire (as in, flame coming back through one of the carburetors), or misfire (as in popping or flame out the exhaust)?
    Backfire is usually a timing issue and is hard to have happen on these bikes because the timing doesn't really allow for something to cause it to be that far off. It could also be caused by significant carbon in the combustion chamber, though (igniting the incoming air/fuel mixture when the intake valve opens), or by a bad intake valve.
    Misfire could be normal (under decel), an leak in the exhaust system, a bad valve (usually an exhaust valve), too rich (leaving extra fuel in the exhaust to be ignited later), or a non-firing cylinder (leaving extra fuel in the exhaust system to be ignited later).
  5. chadall3n
    chadall3n Member
    Clinton, MA
    Re: backfiring
    its popping out the exhaust when engine braking. It also died tonite. I did run seafoam in it on friday and put about 100 miles on it since then. today it started bogging out and eventually stalled and would not start. It started again about 10 minutes later and died again in about a mile. Im thinking the seafoam cleaned alot of crap on the inside of the tank and carbs and is sending it thru the jets and cloggin them. Any ideas? Also when it did finally start it ran perfect for about a minute.
  6. chadall3n
    chadall3n Member
    Clinton, MA
    Re: backfiring
    the plugs looked ok but I am no expert. I will pull them out again 2moro and try to get pics up. also the top of the plugs seemed moist like water has gotten in past the boots.
  7. Polock
    check the valve clearance
