Hole in fuel bowl?
Discussion in 'XJ Technical Chat' started by protomillenium, Sep 7, 2009.
  1. protomillenium
    protomillenium Member
    New Buffalo, Michigan
    Riddle me this Batman:
    Who in a perfectly fine bowl, would find a very fine hole?
    Of course, only a fool! :roll:
  2. chacal
    Someone who tried to drill open the bowl to access the starter jet?
    Or drilled through the starter jet from above, to try and clean it out.............
  3. helmet
    helmet Member
    sounds like a job for JB Weld until you can get another bowl
  4. protomillenium
    We'll see how long the JB Weld will hold, Robin.
  5. helmet
    helmet Member
    Holy fuel bowl hole, Batman!
    I have this stuff called "seal-all" that I got at the parts store, and it seems to work well with everything. even petro resistant.
  6. protomillenium
    It was closed and only recently started to leak, so maybe your second option caused the hole.
    I thought it could be a casting flaw, but it's perfectly round.
    Bill
  7. RickCoMatic
    That's the reason you should Chuck the Drill Bit to a measured depth, or Tape the Drill Bit for a visual marker of how far into the stock you have drilled.
    You can Drill the spot where it came through the Outside of the Bowl to the Outside Diameter of a B-B, or a small Bearing ball.
    Set the B-B or Bearing on the Hole and Seat it into the Hole with a Drift and a few Taps of a Hammer.
    Once the B-B is set into the Hole ... Heat and Sweat with Silver Solder
  8. MiCarl
    Ought to check and see if the starter jet is drilled that diameter too. If so, might not be worth fixing the hole.
  9. Polock
    tiny screw and a tiny o-ring, TIG weld, scotch tape, bubble gum, new bowl
    in that order
    silver solder + aluminum = no
  10. helmet
    helmet Member
    you forgot Duct Tape
  11. schmuckaholic
    California
    Reminds me of a user .sig I saw on another online forum I used to inhabit:
    "You only need two tools in your box: WD40 and duct tape. If it doesn't move and it's supposed to, use the WD40. If it moves and it shouldn't, use the tape."
  12. chacal
    Wonder how that fella's bikes is running? 8O
  13. schmuckaholic
    California
    I don't really know, seeing as how the person in question is a pinsetter mechanic...
  14. chacal
    Oh...........
  15. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    You need some Aladin brazing rod go down to your welding supply store tell them you need to gas weld some aluminum. I've used it on many cast alum. parts it works really well just don't get it too hot. 8O you'll end up with a lot bigger hole.
  16. bigfitz52
    Get it clean and pack it with JBWeld.
  17. RickCoMatic
    I could just send you a Bowl that's not drilled-out ... yet!
    I have some Fuel Bowls that are U-G-L-Y with Varnish and Drain Screws I failed to get out.
    5-Bucks plus shipping and the Bad Dream is yours!
  18. protomillenium
    Your offer sounds good, even with frozen drain screws. I'm surprised you haven't drilled and extracted them already. Still, I cleaned up the area and pushed down a dab of JB Weld into the hole just to have done with it. I got to get riding! A few months will tell if it's good.
    Thanks!
