Coolant Leak 85 Maxim X
Discussion in 'XJ Technical Chat' started by NCBIKER, Sep 22, 2009.
  1. NCBIKER
    NCBIKER New Member
    Monroe North Carolina
    Help
    I have a 1985 Maxim X that sprung a leak the other day and I cannot seem to get it stopped. Removed the coolant tube from the lower rad to the engine and replaced the o-ring with a o-ring from my local lowes.
    I have now replaced it 6 times using different sizes. Stopped leaking for 2 days but last night started to leak again. What the heck am I doing wrong here.
  2. johno8
    johno8 Member
    Can you post some pics of where the leak is coming from? I had a leak on mine and it turned out to be coming from the water pump gasket, not the pipe. The leak looked like it was from the tube, but turned out higher up the engine. As well as the gasket, I used some water pump sealer stuff on the gasket and the leak stopped.
  3. NCBIKER
    NCBIKER New Member
    I will try to get some pics this evening, very hard to see because of how tight the area is.
