front end 1983 xj 750
Discussion in 'XJ Technical Chat' started by jcboyd, Oct 11, 2009.
  1. jcboyd
    jcboyd Member
    Dickinson, Texas
    My front end is "bouncy".
    About every 30ft or so the front end will have a little up & down bounce to it. Nothing drastic but you can feel it.
    Also if you let go of the handlebars it will start doing a tank slapper on you.
    Holding the bars it feels fine, even with one hand.
    Could this be the front springs, wheel out of balance, or maybe more air in my front shocks?
  2. Polock
    get the front wheel off the ground, (center stand, someone on the passenger seat) move the bars slowly back and forth past center if you feel a bump at center or the bars want to self center your steering stem bearings are shot
    then grab the front tire, pull push and try to notice any play
    if theres play maybe you can tighten it out, then check it on center again
  3. jcboyd
    jcboyd Member
    Dickinson, Texas
    thanx I will give that a try.
    Will update you later
