'82 XJ1100J First gear set.....
Discussion in 'For Sale, Trade/Swap, Wanted' started by mikeames, Oct 3, 2009.
  1. mikeames
    mikeames Member
    Vancouver, WA
    I recently replaced my first gear set in my '82 XJ1100J. I decided not to do the famous dremel fix. I found new gears from extremepowersports.com for just under $250 for the pair!.
    THEY DEFINITELY NEED TO BE REPAIRED BEFORE USE as they were slipping out quite regularly...that's why I replaced them. This is a common failure on '82 XJ1100's.
    At any rate I have the used first gears I no longer need for sale or trade...
    As far as trades are concerned I need the following for an '82 XJ1100J:
    -Exhaust header/collector assembly, especially right side. Mechanically very good, don't care so much about chrome. Would consider whole exhaust system for the right price.
    -Gas tank with zero dents and no rust.
    -Rear turn signal mounting bushings.
    -Headlight bezel and bucket in very good condition (no dents or bends, good chrome).
    -Stock "Yamaha" dual horns in working order.
    -Emblem for rear black plastic grab bar/sissy bar.
    -Fork Lock assembly (w/key) that installs on fork tube/triple tree.
    If no trade, make offer on gears....
    Mike
  2. yamikaze
    yamikaze New Member
