XJ700x heads vs XJ750X heads
Discussion in 'XJ Technical Chat' started by nkavanau, Oct 22, 2009.
  1. nkavanau
    nkavanau Member
    Vancouver BC
    Can the XJ700x heads be used on the XJ750x motor? I know the bore and stroke are different, but not sure about the heads. Want to rebuild a spare one to keep on hand and the 750's are a little harder to find.
  2. schmuckaholic
    California
    I believe, and the Maxim-X site seems to confirm, that the bore is the same between the two; the difference lies in the stroke.
    I'd confirm this with HAP first, but to the best of my knowledge, the head should interchange between the two engines.
  3. JoeFriday77
    JoeFriday77 Member
    North Texas
    My understanding is the same. They just changed the cc rating with the stroke.
  4. littlegiant
    littlegiant Member
    Toronto, Canada
    Intersting and GOOD to KNOW.
  5. nkavanau
    nkavanau Member
    Vancouver BC
    Thanks guys. You are correct on the bore, they are both he same.
    XJ750X Bore x Stroke: 68.0 x 51.6 mm
    XJ700X Bore x Stroke: 68.0 x 48.0 mm
    With the lack of 750 parts, that's one less thig to worry about.
    So it looks like the only difference between the two blocks is the con rod length, and carb jets. Sound right?
  6. JoeFriday77
    JoeFriday77 Member
    North Texas
    That matches my understanding between the two.
  7. nkavanau
    nkavanau Member
    Vancouver BC
    OK, now I think I made an error on that assumption. Wouldn't it be the crankshaft that dictates the stroke, and not the con rods?
    Wouldn't it make sense that no matter what length con rods are put on, the stroke could never be greater or less than the travel of the con rod journal from BDC to TDC?? So if that stands true, wouldn't the 700X and 750X have to be using different cranks??
    Just thinking independently, something the wife says I shouldn't do..
