1982 xj750rj seca streetfighter build
Discussion in 'XJ Modifications' started by bossnoss77, Aug 7, 2009.
  1. bossnoss77
    bossnoss77 Member
    orem utah
    alright ive posted some pics of some little mods ive done to my seca but im afraid im going to start making some big changes!
    I have also pick up a second Seca and am going to make a hard tail bob as well. The album is coming thanks for all your insight. :twisted:
  2. bossnoss77
    bossnoss77 Member
    orem utah
    start stock boring
  3. bossnoss77
    bossnoss77 Member
    orem utah
    step two handle bars, 4 into one and forward controls, and air filters and jet kit
  4. bossnoss77
    bossnoss77 Member
    orem utah
    step three new tires, shorter rear shocks, new bars,
  5. bossnoss77
    bossnoss77 Member
    orem utah
    step 4, new mirrors, strip down, new blinks (led), mod out tail light, pop off fender
  6. bossnoss77
    bossnoss77 Member
    orem utah
    well that will get you up to date on my project. Ive enjoyed looking at everyone elses projects so i put mine on. next.....
    gauges and lights, change out to traditional hydraulic mc and braided lines.
    i was thinking about an acewell gauge any comments???
  7. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    What bars did you use? I like them
    Looking good....
  8. xulf13
    xulf13 Member
    Franklinton, NC USA
    Boss:
    How is your bike running after adding those pods? Did you do anything else besides the pods, like bigger jets, etc...?
  9. bossnoss77
    bossnoss77 Member
    orem utah
    YEAH I PURCHASED THE DYNOJET STAGE 1 AND 3 KIT FROM DYNOJET.
    LIKE 120 BUCKS OF EBAY. I ENDED UP WITH BIGGER JETS AND DIFFERANT NEEDLES AND DRILLED THE SLIDES. NOT FOR SURE ON DRILLING THE SLIDE I AM GOING TO PUT SOME STOCK ONES BACK IN AND SEE IF IT ACCELERATES HARDER. iT RUNS REALLY GOOD WITH THE CARBS SYNCED AND THE A/F MIXTURE GOOD FOR MY ALTITTUDE.
  10. bossnoss77
    bossnoss77 Member
    orem utah
    :twisted: the lights and gauges are gone, i will be replacing the controls, lights, gauges and brake lines asap!! pic coming soon.... :twisted:
  11. jarreddaughtry
    jarreddaughtry Member
    Smithfield, N.C.
    Their is nothing wrong with the classic looking atari gauges, but in todays time you need something a little more mean looking. Any of todays gauges would look better than the ataris. I am looking foward to seeing the completed project. Good work it is looking great.
  12. bossnoss77
    bossnoss77 Member
    orem utah
    ok here is what is going on now.....new tank, no back end, new master cylinder and clutch perch, new controls
  13. bossnoss77
    bossnoss77 Member
    orem utah
    well i havent posted any updates for a while. I finally got my battery box finished and my fender mounted and mt electronics panel mounted as well.
    here are the latest photos
  14. bossnoss77
    bossnoss77 Member
    orem utah
    here are the latest photos.
    After i stripped my frame down completely I cut all the extra brackets off.
    the I welded up all the holes. I cut the ass end off and welded up some sheet metal over the tubes to get the shape I was after.
    I wanted to mount a fender with the same lines as the rear frame tube.
    I couldn't decide how to mount it. I wanted to do something a little different then the hard tail bobbers. Im building one of those too.
    SO i built the battery box welded in a plate for the electronics. mounted the box to it and mounted the fender to the box. It works great i also weled some nuts into the frame on the inside to mount the rear fender so it would have four mounting locations. It turned out good I'm pretty jazzed about it.
    i cant wait to get it blasted so i can paint and put it together. I am still trying to figure out what seat, what seat, what seat!
  15. Plumber
    Plumber Member
    Wales
    now you talking, love your work. cant wait to see more
  16. xulf13
    xulf13 Member
    Franklinton, NC USA
    Hey Bossnoss, what are the switches in the battery box for? And why did you make the box so big? are you doing something with the other space?
    It's looking good.
  17. bossnoss77
    bossnoss77 Member
    orem utah
    i made the box big to replicate an oil tank. and to fill the space so it didnt look like a big empty hole. no switches on the tank just bolts welded in to mount it to the frame
  18. bossnoss77
    bossnoss77 Member
    orem utah
    here is a pic of the bike almost finished. i need to get some more recent ones. i have been riding it for some time and it rides really nice. i havent painted it though it is in junkyard form if you will. rat bike hahaha
  19. 209SECA
    209SECA Member
    MANTECA CA
    Looks great!! Clean ride!!! Where did you get the gauge? Have you been to WWW.CUSTOMFIGHTERS.COM ? Awsome forum.
