What sprocket fits middle gear box splines?
Discussion in 'XJ Modifications' started by TECHLINETOM, Nov 10, 2009.
  1. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    Does anyone (Chacal?) know what sprocket will fit the middle gear box shaft of my xj1100?
    The smaller the better and it needs to be a 530 or 630 chain.
    Thanks in Advance
  2. TIMEtoRIDE
    Break out the welder !!
  3. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    No,no,no.
    I measured and it has a major diameter of 30mm a minor diameter of 26mm 6 splines that are 6mm wide.
    I think kz650 ans gs1150 fit.
  4. Kickaha
    New Zealand
  5. earz_cd
    earz_cd Member
    Jefferson city, MO
  6. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
  7. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    Yes Please I would very much like one to test fit!
    PM sent
    Also I found out that a fj1100 or a Suzuki 1200 Bandit rear sprocket would work. The fj has a 150mm bolt circle and the Bandit has a 100mm bolt circle.Does anyone have an extra rear wheel from an xj1100 that you could measure the bolt circle? Also could anyone put up pictures of the rear drive? thanks in ADVANCE
  8. Hillsy
    Hillsy Member
    Go back to the JT Sprockets website and search for the XJ1100. They have pics of the sprockets with bolt spacings and diameters.
  9. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    thanks but the XJ1100 is shaft drive.
    That's what started this whole mess! :wink:
  10. Hillsy
    Hillsy Member
    I thought you were asking about sprocket bolt spacings.
  11. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    No, I need the spacing for the cushion drive to the wheel.
  12. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    Thanks earz_cd i got and it fits the shaft perfectly!
  13. earz_cd
    earz_cd Member
    Jefferson city, MO
    Glad it's gonna work for you.
  14. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    I have some new information about the conversion.
    a 13 and 14 tooth will fit and a15 might.
    The case needs to be clearanced to fit a chain.
    Shaft support bearings are available @ Grainger for about $30 a piece
    Sprocket Specialists has 13t and 14t sprockets available for about $25
    I'll post again when I have more info about the conversion.
  15. Cooter
    Cooter Member
    Chi-Caw-Go
    Any updates on this yet?
  16. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    Not Yet.
    It would cost a great deal of time and money to make the fixtures to mount the shaft.
    The original middle drive casting I don't think would be sutable to modify
    to carry the sprocket.
    I haven't even looked @ the rear situation except that a Suzuki Bandit 1200
    Rear sprocket might be sutable.
    I have purchased an XS850 rear drive and will be installing it soon.
