Electrical issue.
Discussion in 'XJ Technical Chat' started by dwatson636, Nov 23, 2009.
  1. dwatson636
    dwatson636 Member
    Laveen AZ.
    Hi, 1982 XJ650J Maxim
    I have a bit of an electrical issue.
    A: my blinkers or slow, or stopped when I idle.
    B: When I flip my high beam on, the engine dies.
    I checked the output voltage. The book says 14.2 to 14.8 Volts.
    I am getting about 13.6 to 13.8 Volts
    I checked the alternator resistance.
    The book says 3.6 to 4.4 between the green and brown wires. I am getting 6.6
    And I am getting sporadic to no readings across the 3 white wires.
    Any idea what needs to be replaced? or checked?
    Thanks in advance.
    Dave
  2. wizard
    Check the length of the brushes, the outside one wears twice as quick as the other.
  3. dwatson636
    dwatson636 Member
    Laveen AZ.
    The brushes. In what, the alternator? Where and how do I do that?
    Dave
  4. wizard
    Take off the alternator cover (3 bolts) the brushes are fixed to the cover.
    While you are in there, pollish up the rotor with some 800 paper, then sloosh the whole thing out with electrical contact cleaner.
  5. dwatson636
    dwatson636 Member
    Laveen AZ.
    OK, So on the left side there is a cover with three hex allen wrench screws. When I remove it, what specifically am I looking at the brushes for? Length, cleanliness??
    Sorry have not done anything with a bike for about 20 years.
    Dave
  6. dwatson636
    dwatson636 Member
    Laveen AZ.
    OK, so I took off the cover and measured the brushes. Not what I expected them to look like. They were 11 cm. The rotor was pretty dirty, so I shined it up and since I did not have electrical cleaner, I sprayed some wd40 on a rag and wiped it clean. Put it all back together and presto 14.26 volts at 2000 rpm. When the weekend comes, I will get some electrical cleaner and open it up again and clean it a little better. But I ride it to work everyday and needed to fix it tonight.
    Thanks for all the great help.
    A little at a time and I won't feel to bad opening this stuff up.
    Dave
  7. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Are you sure that first XJ you had wasn't a 550 beings it was chain drive?
  8. Robert
    11cm??? I do hope you miss-typed. Should be 11mm.
    Additionally, you will find that the alternator does not kick in until you reach about 1800rpm. Ergo the blinkers won't cycle until the added current is available (you are running on the battery until then).
  9. dwatson636
    dwatson636 Member
    Laveen AZ.
    Sorry Yes it was 11mm. Everything seemed to go OK on the ride to and from work.
    As far as my 82 650 with chain drive. It has been 20 years, but I do believe it was a 650 maxim with chain drive.
  10. Robert
    One way to eliminate all doubt concerning your 650 chain drive Maxim, post the first 5 or so digits of your VIN. Might be hard since you sold it years ago but it would be the definitive evidence. To my knowledge, there was no XJ 650 chain drive Maxim made.
  11. dwatson636
    dwatson636 Member
    Laveen AZ.
    Interesting
  12. Gamuru
    Gamuru Guest
    Granite Falls, WA
    If the electrical issues persist while at idle you may need a new battery. Have it load-tested to check its condition.
