Compression checker
Discussion in 'XJ Technical Chat' started by mikeg, Dec 18, 2009.
  1. mikeg
    mikeg Member
    Milton, Vermont
    What should I look for in a compression checker? I see them on ebay ranging in price from $6 to well over $100. I don't imagine I'll use it often but I figure I should check the compression before I do the carbs and valve shims.
    thanks,
    mikeg
  2. Robert
    I would spring for the one you can afford. Dead accuracy will cost and for what we are doing here, 2 psi either way isn't a big issue.
    I own an Equus and a Sears homebrand, they both work just fine.
  3. wizard
    Get the valves in spec before you check the compression.
  4. RickCoMatic
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Do not buy the style of gauge that uses a rubber nozzle that you hold in the spark plug hole. It’s hard to get and keep a good seal while testing.
  6. bigfitz52
    The one Rick mentioned is also commonly available at most Auto Parts stores for around the same price.
    I've got a couple of them, paid $20 (years ago) $30 (recently) and they work fine. Lostboy is right though, you want a screw-in type.
    "Utility grade" is all you need in this application.
  7. NJRIDER1
    NJRIDER1 Member
    southern, NJ
    the one i got from www.harborfreight.com was 25.99 if you use a coupon you can save more they have several styles and the one i have works fine, it's not the best quality but does the job for as often as i need it.
