Oil level risen and smells like gasoline
Discussion in 'XJ Technical Chat' started by ryanismyname, Dec 23, 2009.
  1. ryanismyname
    ryanismyname Member
    Baltimore, MD
    I still haven't fixed the floats on my Seca 750 so it's still running VERY rich. I've stopped riding it but tonight I took it out for a quick spin because I was out of the country last week and am leaving town again tomorrow. It's been real cold here and I don't want to kill the battery.
    I checked the oil level after a 10 minute ride and saw that it was above the top of the sight window. I assumed gas entered the case and sure enough the fill hole reeked of gas. I know the engine is running real rich but how is that much gas getting inside to the oil pan?
    Now I'm really through riding it until I fix the carbs.
  2. wizard
    It goes down the cylinders.
    Pull the fuel line & check the petcock is shutting off.
  3. ryanismyname
    ryanismyname Member
    Baltimore, MD
    Just realized I posted this in the wrong section. Whooops.
    Thanks. I will check the petcock.
  4. RickCoMatic
    Until you can get to the root problem ... you can get a Briggs & Stratton Fuel Line Shut-Off Valve at a Hardware Store and install it next to the Petcock.
    Cheap quick fix until you deal with the Petcock Leak.
    They come straight line or right angle.
  5. bigfitz52
    Ryan; It's a two-pronged problem. If everything was working correctly, you could (theoretically) leave it on PRI all the time and the floats would shut off the flow. It takes a float problem (may not be adjustment, could be crud) AND a leaky petcock to fill the crankcase with gas.
  6. vintagerice
    vintagerice Member
    New Hampshire
    Rut Ro Raggy! That sucks....
    Rob
  7. seaguy
    seaguy Member
    Coastal,AL
    A black plug might tell on the leaky float.
  8. albran
    albran Member
    DFW, USA
    Quoting bigfitz52 “It's a two-pronged problem”
    2 of the following have to happen at the same time.
    Defective petcock (I had/have this problem)
    Non floating float/s (a Yamaha mechanic told me he had seen some bad black floats)
    Improperly adjusted float (I had this)
    One or more leaking needle seat/s (I had this)
    Edit Quote: “It's a two, three or four-pronged problem”
    ab
  9. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Ryan, pull the battery, take it inside your house and put it on a trickle charger or battery conditioner. This will help it last!
    Loren
  10. ryanismyname
    ryanismyname Member
    Baltimore, MD
    Thanks for your suggestions. I'm positive the floats need to be adjusted, as all 4 plugs are black. I just didn't realize mis-adjusted floats would let THAT much gasoline past the piston. Once we have a day above the 30's I'll take the carbs off again and adjust the floats, put in new plugs, and change the oil.
  11. TIMEtoRIDE
    You can save yourself a little time by checking the float level now- - "as-is" then see if at least ONE of your carbs is close, or right on, then adjust the other 3 to match, then re-check on the bench.
  12. ryanismyname
    ryanismyname Member
    Baltimore, MD
    All 4 plugs are fouled, so wouldn't that mean all 4 floats are set too high?
  13. TIMEtoRIDE
    No, It means you are getting too much fuel.
    It COULD mean all 4 floats are set equally wrong.
    It could mean all 4 pilots are set wrong.
    It could mean you have a pluged air filter.
    it could mean your "choke" doesn't close.
    It could be due to a crankcase full of gas, the vapors make you run rich.
    It's a process of elimination.
  14. ryanismyname
    ryanismyname Member
    Baltimore, MD
    Ok. Thanks.
    I know it's not the choke sticking because I disassembled that entire linkage, cleaned and polished it, and checked it when I rebuilt the carbs. The pilots were set to the factory setting, and the airfilters aren't clogged. I have pods and they were all checked during the rebuild.
  15. RickCoMatic
    Add: Diaphragm Pistons failing to descend do to Oxidation in the Bores.
    Start at the Petcock and Troubleshoot your way down through the Carbs.
    Approaching 25-30 Years on everything is reason enough to need to not overlook anything in the process.
    Its a good excuse for exchanging the fasteners holding the Fuel Bowls and Carb Hats for new ones.
