custom wiring
Discussion in 'XJ Modifications' started by boatdrinks, Jan 2, 2010.
  1. boatdrinks
    boatdrinks New Member
    I recieved an 80's something 750 maxim I believe (no title, no tins, back of the frame gone). However, the good side is it's showing less than 2500 on the clock, and it runs out really well. Now for the question. I would like to eliminate the four hundred pounds of wiring this thing has. I need the bare minimum. I'm NOT running headlights, tailights, blinkers, dash, tach, speedo, brake light, horn, or any other gizmos.
    What I would like is a on/off toggle somewhere and kill switch and starter button on handle bars.
    And all wires used to charge the alt and power the coils and ignition. Is there help out there, or am I just a bit looney? From what I've looked at so far, there has to be at least 100 wires buried in the headlight alone..lol.
    Thanks for your time in advance.
  2. chuckles_no
    chuckles_no Member
    wisconsin
    It shouldn't be too hard. We turned my buddy's Honda Ascott into a dirtbike and removed everything just starting from the component we were eliminating back. The switches will be easy to romove, replace and relocate. If you can splice wiring and can attach desired components, you can do it. The ascott was as easy as pie even though it looked intimidating at first. Also, the Clymer should have a wiring diagram for everything on the bike from the harness.
    Good luck.
  3. skillet
    skillet Active Member
    SW TN
    First, wanted to say WELCOME to the site! Can't really help with the wiring problem yet but SURE hope to end up with minimum wiring, myself. Even with help it's REAL intimidating :oops: . Trying to get everything running as good as possible before tearing it apart :roll: ...
    skillet
  4. dwcopple
    dwcopple Active Member
    bay city, michigan
    search for simplfied wiring. I have posted the diagram numerous times...
  5. vintagerice
    vintagerice Member
    New Hampshire
    Just out of curiosity, What do you plan to do with the bike without all the wiring?
    Rob
  6. boatdrinks
    Is it the "Minimum wiring diagram for Yamaha XJ series"?
    That still looks like greek to me, so I'll have a buddy come over and translate.
  7. boatdrinks
    It'll be running the 1/8th mile at "Hey, You lost?" Dragway. Tech inspection is pretty easy as I'm the inspector. Come to think of it, I own it as well. As long as the state and local boys are patroling elsewhere, the frontage road serves as a nice shutdown area. When they're around, we just bench race....lol. Ahh, country living, you gotta love it.
  8. streetbrawler750
    streetbrawler750 Member
    Minnesota
    It looks scary but it isn't too bad, the hardest part is seperating the throw away vs. the keep, then its a sinch really. I followed the min wiring diagram here and it is a good start I did it a bit different with the fuses, give it a go we are here to help I know I can't be the only one to use the diagram.
    http://www.currentobservations.us/image ... Series.jpg
  9. vintagerice
    vintagerice Member
    New Hampshire
    Sweet... Sounds like a good time..
    Rob
  10. RickCoMatic
    I would:
    Get the Bike running real good.
    Wicked-good.
    Sell it for a profit and buy something worthy of stripping-down or beefing-up to Drag Race.
    Before you lay the first wrench on a XJ-650 to strip it all down to go a short distance, in a straight, line faster than the guy next to you, ... you need to re-evaluate what you can expect from that 650 Plant and Final Drive Unit.
    Even if your Fairy Godmother waves her Twinkling Wand and every conceivable Race-Prep gets done to it, your Times are only going to get so good.
    Most Bone Stock late-model Sport Bikes, in your class, with all their Plastic, extra Skid-bars, Steering Dampers, LED's, GPS, NOS and 12 O'Clock Bars are going to get their riders down to the finish line, with enough time to brew you a Cup-of-Tea before that Yamaha Shaftie crosses-over the line behind them.
  11. chuckles_no
    chuckles_no Member
    wisconsin
    I love it!
  12. boatdrinks
    Don't sugar coat it now, tell me how you really feel Rick...lol. But, you missed one thing, I'm "chief cook and bottle washer" at MY track. I can make the playing field really tilt in my favor...lol. But point taken.
    Now where do I get side covers and a gas tank for a 750 Maxim?
  13. the_namdeeW
    the_namdeeW New Member
    Bay Area, CA
    I am getting rid of my side covers for my 650 Maxim, not sure if they are the same size, but if they are, wanna buy em for cheap? Let me know.
  14. Slammy2k10
    Slammy2k10 New Member
    how cheap is cheap for the maxim side covers? id like to buy em for my 80 XJ650 so i dont have to fabricate shit till i learn more bout this bike.
    Pvt. Assanti, Sam
  15. RickCoMatic
    Side Covers are considered: Hard to Find!
    But, you can get lucky on Ebay or in here.
