TCi or CDi
Discussion in 'XJ Technical Chat' started by corby-boy, Jan 13, 2010.
  1. corby-boy
    corby-boy Member
    Loch Lomond
    Hi i was wondering what ignition modual i have on my 1990 XJ600
    so i can look up any fault finding
    many thanks
  2. corby-boy
    corby-boy Member
    Loch Lomond
    sorry mine is TID14-78 hitachi
  3. MiCarl
    Not sure just what you have. The on line fiches only show an XJ600 in 92 and 93 as the SECA II.
    Those motorcycles have a single pick up coil which seems to indicate a computerized ignition system.
  4. corby-boy
    corby-boy Member
    Loch Lomond
    hi mine has 2 coils
    cheers
  5. markie
    markie Member
    Suffolk, England
    Look for a FJ600 (But the alternator/regulator are different!)
    Corby - Pick up coils, not ignition coils. You definately have a TCI
  6. Robert
    +1^^^ TCI.
  7. corby-boy
    corby-boy Member
    Loch Lomond
    thanks Robert
    nice one
  8. David3aces
    David3aces Member
    St. Pete Fl.
    I think TCI systems are powered by the battery where as CDI systems are powered by a charge coil at the flywheel. Most two stroke dirt bikes have CDI and street bikes have TCI.
  9. MiCarl
    I'm not an electronics guru but my impression is that a TCI is a more advanced system than a CDI. My guess is that a CDI requires some form of mechanical spark advance wherea TCI does not.
    In 1990 Yamaha switched the Venture from a TCI to a Computer Controlled Ignition. I suspect that system allows more precise control of the advance curve and can be programmed differently for different applications. A TCI would require component changes for differing applications.
    Since the Computer Controlled Ignition calculates the spark timing only one pick up coil is used (the earlier Ventures had 4).
    The SECAII has only one pick up coil (Computer Controlled Ignition). My guess is that around 1990 Yamaha switched all their street motorcycles to Computer Controlled Ignition.
    The Yamaha diagnostic procedure for the CCI is the same as for the TCI: Check everything else and if nothing else is defective replace the igniter.
  10. corby-boy
    corby-boy Member
    Loch Lomond
    Did a check found no 12v going to the unit turned out to be a dodgey spade connector all is good running great roll on spring
    thanks for everyones help
