Carb intake boots- where to find them?
Discussion in 'XJ Technical Chat' started by cruisingram, Jan 16, 2010.
  1. cruisingram
    cruisingram New Member
    Need a set for a 1980 650 Maxim, I notice the Seca has different carbs and boots!
    Anyone know where I can get some new or used?
    p.s.- I also need a cam cover, the chain chewed a small leak into the top of the cam cover on the Maxim! :(
  2. danno
    danno Member
    Union Springs,New York
    Chacal (XJforever), a member of this site, can probably hook you up with a new set at a great price. He is THE MAN!!! Btw, welcome to the site!
  3. frankenbiker
    frankenbiker Member
    gobles michigan
    I agree Chacol is the man you need to talk with, and let me say welcome also
  4. vintagerice
    vintagerice Member
    New Hampshire
    Cruising.. I have a set for sale. They are used, had light cracking on the outside that did not go thru on the inside. I cleaned them up and resealed them with RTV and they are fairly pliable.
    follow this link for a look see
    http://www.xjbikes.com/Forums/viewtopic/t=22875.html
    Make me an offer. Like to move them soon. Or Chacal has them new for about $220
    Rob
  5. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    1 1/2" Plumbing Coupling from the carbs to the airbox. The length needs to be shortened a bit, but works great.
    From the carbs to the engine, go to partsnmore.com. I got a set there a couple years back for $90, they're $100 now.
    Hope this info was helpful.
