Back together and rolling again!!
Discussion in 'Hangout Lounge' started by Creamsoda, Feb 21, 2010.
  1. Creamsoda
    Creamsoda Member
    Just got my bike back together after some major cleaning and a few repairs. Replaced the valve cover gasket and donuts, rebuilt the starter, polished a few things, new plugs, cleaned the carbs, new air filter, and best of all new paint!! So here are the first pics I have posted of my bike and to me it's starting to look good. A few other things like new exhaust and bit more spit and polish and things will be looking really good.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. chuckles_no
    chuckles_no Member
    wisconsin
    That is sweet, dude. The tank makes that bike for sure.
  3. skillet
    skillet Active Member
    SW TN
    You've sure got it looking GOOD! Another fan of the paint job on your tank...
    skillet
  4. FABFABINC
    FABFABINC Member
    Montreal canada
    Nice lookiing 650 very nice!!!!!!!!!!! ENJOY
  5. Creamsoda
    Creamsoda Member
    Thanks for the compliments
  6. tonuptony
    tonuptony New Member
    N.E.Scotland
    Mr Creamsoda that bike is a credit to you sir,not over the top but very tasty.
  7. wizard
    That looks the biz, Creamsoda, well done, maybe the air brushing should be on the side panels as well, but hey, what a nice looking bike. Wiz.............
  8. Strick
    Strick Member
    Ft. Eustis, Va
    That is very nice looking bike. You make me want to take my pictures of mine off of here. I am ashamed of how mine looks compared to yours. My bike is still a work in progress. Looking sweet there Creamsoda.
  9. FABFABINC
    FABFABINC Member
    Montreal canada
    Creamsoda! I think your front tire is on the wrong way.
  10. chacal
    FAB-----you good!
    Now, explain to him why that's a problem that he might want to remedy pronto......
  11. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Great looking bike man. I missed the front tire thing, but I'm surprised Wiz missed it. He's the Wiz! :wink:
  12. FABFABINC
    FABFABINC Member
    Montreal canada
    Well lets not forget I'm in the industry lol but here is a good reason why. Directional designs are recognized by the grooves in the tread that swipe away in a backward angle from the center of the tread face and rotate in only one direction. A direction of rotation arrow is located on both sidewalls of the tire. Directional tires enhance straight-line acceleration , provide maximum dry traction , and better wet performance which helps to reduce rolling resistance as well as providing shorter stopping distances.
    Fab
  13. chacal
    This is a really important reason, too!
    Tires Directional Arrows Explained By Avon Tyres
    Published by Cyril Huze
    August 23rd, 2009
    Before we can talk about directional arrows you must first understand a bit about tread patterns. There are many different tread patterns but there is one main reason to have any tread and that is to disperse water (dust, dirt, etc.).
    A tread pattern can be designed to disperse more water by making it rotate in only one direction. Thus, the need for directional arrows. The arrow tells you which way to mount a tire for maximum water dispersal.
    Another, less apparent reason for directional arrows is the tread splice. What is a tread splice? When a tire is manufactured the tread portion of the tire starts out as a long flat strip. This strip is wrapped around the tire and the two ends are cut on an angle so one end overlaps the other rather than having square cut ends.
    This overlapping point or splice offers a bigger surface area to bond together, rather than the small surface area provided by square cut ends. (Imagine gluing your fingertips together, as opposed to gluing along the entire length of your fingers laid on top of each other. Like an angled splice, the overlapping fingers result in a much stronger bond).
    To further ensure the strength of this bond along the tread splice the directional arrow will show you which way to mount the tire so that when the rider is “on the gas”; the acceleration force on the rear tire is pressing the splice together, rather than peeling it back.
    As for braking, 80 % of the braking should take place in the front on most bikes. Therefore, the front tread splice is run in the opposite direction than that of the rear, so when the rider is on the brakes, he’s not peeling the tread splice back.
    Suffice it to say that you do not want to introduce a condition where an internal tread splice might fail, becuase when they do, it can result in an immediate and catastrophic failure of the entire tire!
  14. FABFABINC
    FABFABINC Member
    Montreal canada
    10-4 Chac ;)
  15. Creamsoda
    Creamsoda Member
    Well thanks for the info guys and I appreciate the concern.... in response I ran out to see which direction the arrows are pointing and according to what I am seeing the arrows are pointing in a clockwise direction. Which according to my understanding of the info you all gave means the tire is actually on correctly.
  16. wizard
    Clockwise is good, if you are going backwards.........
  17. Creamsoda
    Creamsoda Member
    Ok I am confused the arrow is pointing in the direct the tire would be rotating if moving forward at least thats what I am seeing. So which way is the arrow suppose to be pointing.
  18. Creamsoda
    Creamsoda Member
    ok I went and looked again and are we talking about the direction arrow or the actual tread here guys becuase I am confused. to me the arrow says the tire is on correctly but I understand the tread does seem backwards. It would surprise me since the PO didn't know diddly about anything on this bike. All I know is that I have owned th bike since June of 09 and the the tires are about two years old according to the PO which means it has always been on the wrong way.
  19. wizard
    If the arrow is pointing in a forward direction, that is right, but that isn't clockwise.............
  20. Kickaha
    New Zealand
    Looks like a Metzler ME33? in which case it is fitted correctly, things aren't always as they seem when it come to Tread patterns
    In car tyres they might be, bike tyres like the ME33 and some models of Avon tyres they are the opposite of what you would expect
  21. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Yep that one model of tire, looks backwards, but is actually on correctly.
  22. FABFABINC
    FABFABINC Member
    Montreal canada
    Indeed I'm on the car side in the tire industry sorry for opening a can of worms.
    Fab
  23. wizard
    Don't you wish you had pulled your neck in, sometimes? :wink:
  24. skillet
    SW TN
    Been there, done that and bought the goshdarned Tshirt :oops: ! This too shall pass :wink: ...
    skillet
