Exhaust flange bolts
Discussion in 'Hangout Lounge' started by razz1969, Feb 25, 2010.
  1. razz1969
    razz1969 Active Member
    Cleveland, Tx
    I am currently in the beginning stages of restoring my bike to as new. But in order to do it RIGHT I really need to take the engine out. That doesn't bother me but what does is the exhaust flange bolts. I am terribly afraid of breaking them off. So afraid I am to the point of not taking the engine out and working around it. Any comments on this or any sugestions on removing said bolts.
  2. skillet
    skillet Active Member
    SW TN
    Hope someone comes up with a REAL GOOD reply!!! All the pics I've seen of removed engines, are they just lucky?
    skillet
  3. bigfitz52
    They are supposed to be nuts on studs. Did yours get replaced with bolts along the way?
    If they're original and never been touched, they're not very tight (not supposed to be.) Soak 'em in Kroil for a couple days then carefully unscrew them.
  4. TMHack
    TMHack Member
    Green Bay, WI
    When I took mine out I soaked them in PB blaster for a day or before going at them. I already had replacements so I just went at them with a vice grips as tight and as close to the head as I could and luckily they all came loose fairly easy. If that doesn't work heat(and lots of it) can be a very big friend of loosening stuck/corroded bolts, nuts and studs.
  5. tcoop
    tcoop Active Member
    South Weber, Utah
    When I took mine off I didn't soak or spray them with anything. If they felt felt tight I would have stoped and used PB Blast (I got to get some Kroil)
  6. dustinb
    dustinb Member
    Victoria, BC Canada
    I soaked mine with liquid wrench over night, and then the next day sprayed it again and just gently worked it back and forth till they came out. Mine is a nut on stud setup though, and will definitely be putting anti seize compound on it when they go back on.
  7. razz1969
    Cleveland, Tx
    Thanks guys, I feel a little more at ease now. And yes they are nut on studs so I am going to soak them with pb blaster and see what happens. I will keep you posted..
  8. skillet
    SW TN
    :oops: When I looked I just took it for hex headed bolt :oops: ...
    skillet
    BTW does this mean I go back to biker wannabe?
  9. razz1969
    Cleveland, Tx
    Well I did it, easy as pie. All I did was put some PB Blaster on them, started the engine till the PB Blaster started to smoke on the nuts, and like cheap magic, off they came. Almost like they where put on just yesterday. But on a sad note, I had to lay Maxine to rest today, till I put her all back together again. I ran her carbs dry, fogged the cylinders, and took her battery out. There she sat at piece knowing that she will be like new someday,,,,,,,someday soon. Sniff :(
  10. skillet
    SW TN
    Here's to the day she's back on the road. When I get to that point, hopefully mine come off that easy...
    skillet
  11. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    50/50 mix of transmission fluid and acetone is way cheaper than kroil or PB blaster and has been shown in tests to work better as a penetrating lube. Only annoying thing about it is that the home mechanic could mix up a 2gallon batch of it and leave a gallon and a half behind in his will.
