How to limit front fork travel ?????
Discussion in 'XJ Modifications' started by farmer, Mar 4, 2010.
  1. farmer
    farmer Member
    Does anyone know a reliable way to limit front fork travel. I think i need to lose about 3-4 inches at most of travel. See my turbo build. Basically I need to limit travel so that the intercooler does not hit the front fender.
    Anyone have any ideas?
  2. tcoop
    tcoop Active Member
    South Weber, Utah
    Would puting something in your forks to preload the springs help? I've read that some have put pvc pipe in to keep it from diving so much. Juat a thought. New springs from Progresive might help.
  3. RickCoMatic
    If you use Progressive Suspension Springs, ... you need to do as the Instruction Manual recommends.
    To much Preload will cause the Spring to be compressed "Solid".
    Progressive makes different Springs for all the XJ Bikes.
    Get the ones that belong in your Bike.
  4. Kickaha
    New Zealand
    If you loose 3-4 inches you will have pretty much no travel left, you would be better off with either mounting the intercooler elsewhere or fitting a different one which wont get in the way
  5. T0MCAT
    T0MCAT New Member
    CRACKIMA, WA.
    CHOP UP THE FENDER OR TAKE IT OFF. PROBLEM SOLVED.
  6. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    that was my first thought too...
  7. SlightlyOffAxis
    SlightlyOffAxis Member
    1137' ASL South of 90 -5 GMT
    Progressive springs also come with spacers that sit on top to pre-load the suspension. I would be surprised if they didn't work. They significantly reduce the dive on my FJ.
  8. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Heavier weight oil will stiffen them up a bit, but as far as reducing travel, don't think it can be done, like the other guys said if you put in spacers you literally can lock the forks. Longer forks would just screw up the bikes geometry.
