Your thoughts on tank emblems and dents?
Discussion in 'Hangout Lounge' started by xj550, Mar 12, 2010.
  1. xj550
    xj550 Member
    Airdrie, AB
    I am going to be repainting the tank and side covers and was wondering on everyone's opinion on if I should leave the emblems on the tank and covers or take them off?
    Also there is a couple dents in the tank and I have heard that these tanks have a inner coating to prevent rust. Would pulling the dents out damage this coating? Or should I just fill them with bondo?
  2. dwcopple
    dwcopple Active Member
    bay city, michigan
    trust me, there is no coating.
  3. chacal
    Unless someone has previously "lined" the inside of the tank with Kreem, POR-15, etc. type of product............
  4. iwingameover
    iwingameover Active Member
    If they're small dents I'd just fill them.
    As for the badges, that's up to you. I shaved mine both tank and side covers. When i go to paint mine this time (swapped tanks to a 750) I've got my eye on a tuning forks logo decal with some flames. Maybe maybe not. I haven't decided.
  5. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    take the the badges OFF....it might look fine if you do a perfect job of taping, but it's so much easier to get a smooth coat under them when they aren't there.
  6. danno
    danno Member
    Union Springs,New York
    Caution advised! Things can get ugly fast!
  7. winterman97
    winterman97 New Member
    almost considered West Michigan
    I agree with Mike, pull the badges off. Use a heat gun to loosen up the adhesive and they should pull off without damage so when your finished painting you"ll have the option to re-use them. my friend is pulling all the badges off his almost brand new pontiac that way so it should work on 25+ year old glue.
    If the dents dont pop out easily I would bondo, you"ll be doing a lot of sanding anyways.
  8. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    The badges on the 81 550H tank should be held on with screws.
  9. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    The badges on the side panels are held on with double sided tape. Use fishing line like a saw to remove the badges. Do your paint job and reuse the badges with new tape.
  10. chuckles_no
    chuckles_no Member
    wisconsin
    My old tank has a really thick coating on the inside. Haha... rust. As far as the badges go... the heat gun is awesome at it. Go slow and even consider the use of a razor blade. I used to do painting and refinishing (never auto but a lot of metals and some with emblems etc...) and the heat gun makes the adhesive like gooey again. Some spots might be stuck a little harder so the razorblade comes in handy (you are repainting anyway). If you try to just use more force on the areas where it is stuck more you might ripple or tear the emblem (or if a harder plastic it will crease or crack it).
  11. xj550
    xj550 Member
    Airdrie, AB
    I am definitely taking the badges off to paint the tank. I just can't decide if I should reinstall them. The tank ones are held on by screws and the side covers are double sided taped on.
  12. day7a1
    day7a1 Member
    San Diego, CA
    Check the prices for badges on ebay, et al. That might help you decide to put them back on or to sell them. Mine doesn't have any, and I am not planning to put them on for that price, either.
