The road to recovery...
Discussion in 'XJ Technical Chat' started by ski84, Mar 21, 2010.
  1. ski84
    ski84 Member
    New Mexico
    I remember it well, that day in May, 1982 nearly 28 years ago, when I picked her up in Faribault, Minnesota. My two roommates & I were in the market for motorcycles and we all settled on Yamaha’s. We looked at the competition, Honda, Kawasaki and Suzuki, but it was Yamaha that grabbed our attention. I was biased; my uncle was one of the 1st Yamaha dealers in the United States so I was brought up around Yamaha. My roommates settled on the 1981 model 650 Maxim’s that were prior year carry over’s, primarily because of the deep discounted price. I read the articles…Yamaha’s new 750 power plant was the fastest ¼ miler in production. Not one to follow the pack (literally or figuratively), I fell hard for the 750 Maxim. Just a hair more oomph and a little more style, exactly what I was looking for.
    Fast forward 28 years into the future, still together road rash and all… what a labor of love it’s been.
    My quest to restore La Bête began last October when I did a Google search for help on replacing fork seals. Low and behold, XJbikes contributor “Gamuru”, had a write-up detailing fork seal replacements and the info I was looking for. I couldn’t believe my eyes, a site dedicated to the old XJ of yore. The tasks ahead seemed less daunting and the time for procrastination was finally over. Enough blather already… I set a budget for the project at $650 with a mid-March completion date.
    Here’s an itemized list of what a little less than $600 paid for including tools, supplies & riding gear:
    Fork Seals
    Fork tube crush washers
    Front wheel bearings & seals
    Steering stem bearings
    Gas cap seal
    Front tire
    Front brake pads
    Caliper seals
    Caliper boots
    Master cylinder rebuild kit
    Blue instrument LED’s
    High intensity red brake LED”S
    German Osram H4 Silverstar headlight bulb (Sylvania not)
    Harbor Freight Volt meter
    Oil galley o-rings
    Oil sending unit o-ring
    Generator seal & o-ring
    Generator bearing oil nozzle o-ring
    Shifter shaft seal
    Carburetor fuel rail o-rings
    Thorough carburetor cleaning
    Carburetor bowl gaskets
    Valve cover gasket
    Valve cover donuts
    Dynabeads for tire balancing
    Gas/vacuum line clamps
    Rear brake wear indicator plate
    Radio Shack fuse holder
    Radio Shack 12V Relay (275-248)
    Hi temp oil cooler hose (4’)
    Oil filter o-rings
    Oil Filter
    Oil drain crush washer
    12 Volt accessory power port
    Tools added to the shop:
    BrassCraft castle nut holding tool
    YICS Blanking tool
    ColorTune tool
    Homemade carburetor level stand (for float setting)
    Tire irons (3)
    Shim tool
    #2 JIS screwdriver
    Homemade brake vacuum pump (for bleeding brakes)
    Welding tip cleaner
    M16X1.5mm Tap
    Misc supplies used:
    Tropicana juice container wheel protectors
    3M Tank emblem adhesive
    Carb/brake cleaner (4 cans)
    Silicon grease
    Hi temp brake grease
    Moly bearing grease
    Anti-seize paste
    Fork oil
    Marvel Mystery oil
    Blue thread lock
    Brake fluid (16 oz)
    1000 grit Emory cloth
    16 ga hook-up wire
    3/8” clear vinyl tubing (12 ft)
    Various wire splice connectors
    Spray paint - flat black
    Kroil (best $12 ever spent)
    5 Minute Epoxy
    Riding Gear added:
    HJC CL-SP helmet
    Cargo net
    What’s left to do you say?
    Headlight modulator
    Adjust valves
    Sync carbs
    Colortune the Pilot jets
    Helicoil 3 stripped valve cover holes (thanks to Yamaha dealership service)
    Drop the exhaust to replace that darn oil sending unit o-ring
    Rear shocks
    Braided brake lines
    TCI electrolytic capacitor replacement and solder touch-up
    Epiloge
    Parts and supplies were gathered from a variety of sources with our very own “Chacal/Len” as a major supplier. Other supplies came from as far away as Korea, Canada, Estonia, Japan, & Hong Kong.
    Last time La Bête was started: +5 years ago
    Advice: Take your time and do it right
    Goals met: Under budget and on schedule
    Cost of satisfaction: Priceless!
    Almost forgot to mention, the new Maxim hasn’t ran this good in a long, long time. I can’t say for certain, but it’s quite possible that it’s running better today then ever before. Or, at the very least, since that cold March day we kissed the pavement at 70 miles an hour some 22 years ago. Hard to believe I know… I'm jacked to see what I can get with the carbs synced & Colortuned!
    Now for the million dollar question: What do you suppose it would have cost me to have somebody do this work for me? Rhetorical question for sure, and it really doesn’t matter much anyway. Not to mention, I never really liked those grease monkeys working on my bike at the local shops either. Nothing personal, but in general, the mechanics I’ve experienced in New Mexico, can’t or don't cut it. They never seemed to get the job done right or to my satisfaction before they lifted those greenbacks from my wallet.
    Many thanks to all those that inspired and helped me along the way!
    The road to recovery wasn’t quick but it was immensely satisfying…
    Long live the XJ and long live XJBikes.com!
    Ride on,
    “Ski”
    La Bête 2010
  2. guystjames
    guystjames Member
    Ancaster,Ontario-Canada
    Absolutely stunning, looks NEW. You deserve your pride.
  3. streetbrawler750
    streetbrawler750 Member
    Minnesota
  4. skillet
    skillet Active Member
    SW TN
    GREAT history lesson and REALLY NICE looking bike! You've a right to be proud...
    skillet
    BTW and like you said, if it weren't for the more knowledgeable members and their how-to's a number of us wouldn't be riding...
    skillet
  5. schooter
    front page work!
    very glad to seen such a nice example of an xj, you should be proud.
  6. Hack
    Hack Member
    Ontario, Canada
    What a fine looking ride, Ski.
  7. RickCoMatic
    Every great magic trick consists of three parts or acts.
    The first part is called "The Pledge".
    The magician shows you something ordinary: a deck of cards, a bird or a man. He shows you this object. Perhaps he asks you to inspect it to see if it is indeed real, unaltered, normal. But of course... it probably isn't.
    The second act is called "The Turn". The magician takes the ordinary something and makes it do something extraordinary. Now you're looking for the secret... but you won't find it, because of course you're not really looking. You don't really want to know. You want to be fooled. But you wouldn't clap yet. Because making something disappear isn't enough; you have to bring it back. That's why every magic trick has a third act, the hardest part, the part we call:
    "The Prestige"!
    Take a bow.
    Listen to the every well deserved compliment.
    What a great job. But, it's NO illusion, ...
    YOU really brought it back!
  8. yamasarus
    yamasarus Member
    Norh Carolina
    Well done, well done. Be proud. We all know what it took.
  9. MidniteMax
    MidniteMax Member
    Liberty SC
    What an accomplishment!
    Great work!
  10. taboo365
    taboo365 Member
    Great job!!! she looks great! 8)
  11. ski84
    ski84 Member
    New Mexico
    Thanks guys for all the generous compliments!
  12. Babylon
    Babylon Member
    Somerset, United Kingdom
    Indeed you've done the old girl proud!! :D
    Totally agree with everyone in saying without the more learned members of our forum ... alot of us wouldn't be able to afford the bike shop labour costs involved with keeping our beloved XJ's on the road.
    So Ski ... Take a bow
    And also all our resident experts ... See what you have inspired guys!!!
    Regards .. Babylon 8)
