intake boot install
Discussion in 'Hangout Lounge' started by vegabob, Mar 23, 2010.
  1. vegabob
    vegabob New Member
    Derry, PA.
    Hello everyone I am vegabob.
    I am new to this forum and I have an 82 xj1100 maxim that I love deeply and I am changing out the intake boots have all the parts, its apart and going back together but should the gaskets be RTVed or dry.
    Iwould like to thank you all for being here to help and the welth of info on this site. I had the bike for 5 years and think it is worth the time to keep it running the best I can and with some help and info from all of you I just mite. So I mite ask some dumb questions but I rather be an ass than do bad thinks to "Black Maria" she has never let me down.
    Thanks again
    bob
  2. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    Hi vegabob,
    I like to use permatex brand anarobic sealer. I just wipe a very small amount on both sides of gasket "dressing" the gasket if you will. There should be no sealer squishing out if there is you used to much. The stuff is transparent red in a blue tube and will not harden unless its under presure.
    what ever you do if you use sealer make sure it's rated to a high enough temp.
  3. skillet
    skillet Active Member
    SW TN
    WELCOME and I would definitely think it's "worth the time"!!!
    skillet
  4. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    My intake boot had cracks in them. I didn't exactly know if they leaked or not, but I coated them anyway. I used GOOP (this tuff is amazing - even says it on the package) I sealed all the cracks with it,let it set for a day and painted it with high temp paint. Never had a problem since. It dries like hard tire rubber so it still has a bit of "give" to it. Give it a try.
  5. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    I knew what you were talking about bob :lol: the important thing to do on those is to antisieze the bolts!!!! if your boots are cracked bad a little rtv silicone coating will seal up the cracks. and like I said just dress the gasket
    welcome to the sight and good luck,
    James
  6. vegabob
    vegabob New Member
    Derry, PA.
    thanks to everone that helped
    went to auto zone no anaerobic high temp went to advanced auto same did score some red high temp RTV i will use after loocking some more first for the HT anaerobic . replacing boots because of cracks old boots are still good on inside, got new boots it's apart it gets new boots. Will keep old one's to help some one that may need them.
  7. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    they only makr one anarobic sealer :)
  8. vegabob
    vegabob New Member
    Derry, PA.
    thanks again lowlife got some and it seems to work just fine
    The next question is how do I know which carb's I have and which kit to get were to find them
  9. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    send a pm to chacal, excelent service
    just let him know year and model and what pieces your looking for.
    Good Luck,
    James
  10. c21aakevin
    c21aakevin Member
    Macomb, MI
    I use the spray can of RTV Copper to dress most gaskets. It sprays on like paint, so you don't have to worry about getting it too thick.
  11. taboo365
    taboo365 Member
    PainterD! where can I buy this GOOP stuff? Auto parts store? And is that
    the entire name of it? Thanks
