xj1100 compression ratio
Discussion in 'XJ Technical Chat' started by mav2, Mar 26, 2010.
  1. mav2
    mav2 Member
    charlottetown
    hey all, that time of year again.. does anyone know what the compression should be on a xj1100? my bike sat all winter on it's side stand, last week i pulled the plugs and did a compression check, here are my readings.
    1- 240, 2 230 , 3- 180 , and 4 is 170, i suspect that 1 and 2 are higher because the bike sat leand on the stand for so long, but my questuion is what should they be?, whats acceptable?
  2. chacal
    1100 engines:
    Minimum: 128 psi
    Standard: 142 psi
    Maximum: 156 psi
    Max. variance between lowest and highest: 14psi
  3. wizard
    Are you testing dry, with the throttle wide open & the air filter out?
    You could also try with a different tester.
  4. mav2
    mav2 Member
    charlottetown
    actually idid the test with the carbs off,. does that make a difference?
  5. wizard
    no, thats ok, you need the max air passing through.
  6. mav2
    mav2 Member
    charlottetown
    ok, so having the 249 psi on 1 and 2 i suspect it is because the bike was on the side stand and maybe some oil got into the cyls, in any case, i am thinking that valves and rings are ok , unless the ratios stay that way in which case the cyls would be out of balance am i correct there?
  7. TIMEtoRIDE
    OK,
    You need to run the engine for 20 minutes, then do the test.
    You could test the gauge against a good engine, just to check the gauge.
    You might have unknown amounts of oil in there that will increase your readings.
    Gasoline can leak by both the petcock, and the floats, throwing these readings off. Check your oil level. Something's up.
