oil leak
Discussion in 'XJ Technical Chat' started by a_wright06, Mar 31, 2010.
  1. a_wright06
    a_wright06 New Member
    Northern IN
    oil is leaking out of some gaskets in my '82 xj750
    think i should rebuild the motor since it will be out and apart to change the gaskets and paint anyway? if so where can i get all the parts?
    thanks
  2. davstarks
    davstarks Member
    Grayling MI
    Naw, Just park next to the Harleys and nobody will notice.
    Do it, its alway good to know whats going on in there anyway. I got a top end gasket set off ebay for about 45 bucks, but that was before I found this site. chacal has everything you need. While your at it, check your valve clearances.
    Take advice from my screw-up, this is the time to do the fine cleaning and polishing/painting of the engine.
  3. a_wright06
    Northern IN
    lol thanks ill hit up chacal
