New XJ550 Rider with some questions.
Discussion in 'XJ Technical Chat' started by blackhole916, Apr 4, 2010.
  1. blackhole916
    blackhole916 New Member
    Trenton, Michigan
    I picked up a 1982 xj 550 for $700 and have been having no luck finding stuff for it. I was wondering what mufflers i can put on it. I want to make it louder but have not been able to find a muffler at all. Any ideas? Also the chain and chain guard seem really close to the rear tire how far apart is it on some of yours? Thanks
  2. Pazalas
    Pazalas Member
    Reading PA
    Max or SECA?
  3. Pazalas
    Pazalas Member
    Reading PA
    I got mine with a 4 into 1 already on it. some salt water, time and a long rod got my baffels out. Just remeber you have to change your jets and carb shims when adding airflow. Guy didn't do it on mine and im still working on it year after year.
  4. chuckles_no
    chuckles_no Member
    wisconsin
    If you want it really loud you can go straight. I have the Mac 4 into 1 which sounds tastefully loud. But I also had a straight pipe made to replace the muffler on the 4 into 1 headers in case I ever want to bob it out. The Mac is the most popular for these bikes. Check out Bikebandit, ebay, JCWhitney, etc.
  5. BlackMax
    BlackMax Member
    Brampton Ontario
    You can go with sportster mufflers, I went with some 50 dollar aftermarkets that look stock.
  6. feetballhabob
    feetballhabob Member
    Kentucky
    there is a site I think it is called niche cycle or cycle niche they several exhaust you might like.
  7. dfknoll
    dfknoll Member
    Frankenmuth, Michigan
    On my 82 550XJ, the chain guard only clears the rear tire by maybe a half inch. Never had an issue with it rubbing on the tire
  8. blackhole916
    Trenton, Michigan
    Thanks for the help guys I'll have to check some sites out
  9. blackhole916
    Trenton, Michigan
    The chain and chain guard seem closer than 1/2 inch fromk my rear tire id say there is less than a 1/4 inch of space between them. Whats some of your thoughts? thanks
  10. lopezfr2
    lopezfr2 Member
    Point Loma, San Diego, CA
    wheel might not be aligned properly or the tire is bigger than stock. i just took mine off because it actually was rubbing.
  11. blackhole916
    Trenton, Michigan
    What is the stock size do you know?
  12. lopezfr2
    lopezfr2 Member
    130/90 x 16 i believe
  13. scoutout
    scoutout New Member
    Hey, similar question from me too. I've just acquired a 1982 XJ 550 Seca and am also needing new exhaust. Seems like this guy's is 4 into 1, mine is 4 into 2. So do those sportster mufflers fit for the 82 550 seca 4 into 2?
    Thanks.
