which cylinder is #1?
Discussion in 'XJ Technical Chat' started by zacthepain, Apr 13, 2010.
  1. zacthepain
    zacthepain New Member
    Wylie, Tx.
    Hi, I just got done refitting the cylinder head, but now I cant recall which cylinder is #1 to be able to put the plug wires back correctly. If sitting on the bike, is #1 on the left hand or right hand side?
    thanks
  2. skills4lou
    skills4lou Member
    Dillon, MT
    Should be the left side as sitting on the bike.
  3. seaguy
    seaguy Member
    Coastal,AL
    yep. outside left side
  4. zacthepain
    Wylie, Tx.
    wow, thanks for the quick replies guys.
  5. Hillsy
    Hillsy Member
    As far as plug wires go, all you need to know is 2 and 3 are in the middle. Doesn't matter if you swap leads 1 and 4 (or 2 and 3 for that matter) as they both fire off the same coil.
  6. RickCoMatic
    Excuse me?
    What???
    Hold it ... Hold it ... Hold it!!!
    How in the heck were you able to replace a Cylinder Head back on the Engine without being certain about which Cylinder was Number-1.
    If you didn't have Number-1 at Top Dead Center for the reinstall of the Cam Chain and Cams ... you could be in for BIG Problems trying to get that Engine to turn-over.
    Number-1 is the Left Cylinder
    Viewed from the Riding Position
    On the Clutch Lever Side.
  7. Hillsy
    Hillsy Member
    Actually, as far as cam timing is concerned, you could use cyl 1 or 4 as TDC because they are both in sync.
  8. zacthepain
    Wylie, Tx.
    I had the TDC mark on the crank aligned with the marks on the cams. I just couldnt remember which spark plug the #1 wire went to, far left or far right.
  9. grmeyers
    grmeyers Member
    Asheville, NC
    I don't mean to hijack the thread but I had to break the chain on my 650 cam, do you know what a repair link size or number would be?
  10. RickCoMatic
    JOINT, CHAIN (BF05M)
    TSUBAKIMOTO
  11. grmeyers
    grmeyers Member
    Asheville, NC
    Thank you, If I find one that takes a clip instead of the one you need to ping, do you think it would be safe to use?
  12. Hillsy
    Hillsy Member
    Can't say I've ever seen a camchain with a split link before ??
  13. RickCoMatic
    I wouldn't use a "Detachable Master Link"
    I'd make sure the Link was going to be able to handle 8~10K rpm's.
    You got a lot ridin' on that Chain Link.
  14. grmeyers
    grmeyers Member
    Asheville, NC
    Then does the original link take a special tool to to ping it or is there a special way to make sure that is done right? Thanks
  15. prock
    prock Member
    Guelph, Ontario
    what is the firing order? is a spark being wasted?
  16. bigfitz52
    Yes, wasted spark.
  17. RickCoMatic
    The Chain gets a REAL Link which has Link Pins that are Peened-over ... (or "Mushroomed) to secure the Link permanently.
    Search: Motion Pro Chain Tool on the Web
