oil filter conversion
Discussion in 'XJ Technical Chat' started by doug64082, Apr 16, 2010.
  1. doug64082
    doug64082 New Member
    lees summit Mo
    Hi guys im new to the xj family, I went to change my oil and found it almost impossible to get the housing(filter) off. I found you guys and seen that there has been some talk of a spin on filter conversion?? who makes it and where can i get one, this thing drove me nuts? oh btw, it a 1982 xj650 seca.
    thanks, doug
  2. JFStewart
    JFStewart Member
    Ontario Canada
    Chacal has the adapter for a spin on filter. I have found that in cases where the original bolt won't come loose, an impact driver is the cat's meow. Every bike owner should own one in my opinion.
  3. doug64082
    lees summit Mo
    how do i get ahold of them? thanks so much for the help?
  4. davstarks
    davstarks Member
    Grayling MI
  5. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    The spin on filter kit is great.
    BUT...make sure you get the filters with the hex nut welded to the housing. It's much much easier to get them off.
    Len will fill you in.
  6. jammer41
    jammer41 Member
    Rochester, NY
    Or, you could do what the PO of my bike did. take the bolt to the grinding wheel and make it square. (no, don't really do that).
  7. Polock
    there's a picture of one in my gallery,if you want to see what they look like, it's not the one from chacal but it's a very close copy
    i will be making another one for my Seca
