Fork Seals Nightmare
Discussion in 'XJ Technical Chat' started by Axel, Apr 16, 2010.
  1. Axel
    Axel New Member
    4 sets of seals ,new bushings , different set of forks , progressive springs , no air , 12 months , seals leak right away , Yamaha mechanic ,
    Whats wrong with this picture ? XJ1100
  2. RickCoMatic
    There's no picture.
    4 Sets of seals?
    Were they the right seals?
    Different set of forks?
    Right forks?
    Progressive springs?
    Hard to mess up, ... !
    No air?
    Non-pneumatic -or- don't hold any?
    Seals leak right away?
    Must not be the right seals, or they aren't being installed right.
    Yamaha mechanic?
    Your paying somebody to do this and it takes 12 months?
    We don't give-out prized for Posts that are 25-Words or less.
    Write down what happened. Plus the part where it looks like you are getting screwed pretty badly, and tell us what's going on.
    Utilize the Location function to let us know where you are.
    Utilize the Signature Function to give us THUMBS on the Bike.
    Yr -- Miles -- Model -- Stock or Custom
  3. Axel
    Axel New Member
    Right seals ,right forks , hold air but dont use any after the progressive springs. Installation method is about all thats left to question . The guy used to be a Yamaha mechanic . This is the second season with this problem hence the 12 months . Seals always leak right away but to different degrees . this time round one seems ok but one leaks bad - picked it up today .
    XJ1100 65.000 kms Ottawa Ontario
    oh ya - thanks for the attitude - really helps the frustration levels
  4. RickCoMatic
  5. MiCarl
    Know what? Rick is on here helping folks every day. You throw out a few fragments with no cohesive story. All he asked was for you to fill in the details. He's good, but as far as I know he doesn't do the Vulcan mind meld long distance.
    BTW. Time for a new mechanic.
  6. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Sounds like there's some burring or a flaw tearing the seals, check the forks over ..
    and +1 for what MiCarl said.....
  7. Polock
    attitude, thats not attitude
    this is attitude
    they'll only leak till their empty
  8. dusty
    dusty New Member
    Maybe some rust pits on the fork tubes? ...and be nice to Rick :)
  9. bigfitz52
    it doesn't take much of a "divot" in the fork tube to cause some pretty severe leakage.
    Carefully examine the persistently leaky tube for pitting in the area where the seal rides; not just major rust pitting but tiny stone chips or other tiny dings. You can smooth minor ones out with a stone, but major pits means you're going to need a fork tube.
  10. wizard
    Wrong, they still leak when they are empty, just nothing comes out.
  11. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Maybe that's why he "Used to be a mechanic" and like the others said, with only three posts asking for help with minimum info......chill out.
