HIGH IDLE AFTER WARM UP
Discussion in 'XJ Technical Chat' started by 1FASTHOE, Apr 17, 2010.
  1. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    at start up everythings fine, after i ride a short distance, it idles at around 2200 rpm. also it takes a few seconds to come back down after i rev it.
    thanks for your help
  2. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    My suggestions:
    Did you set the idle when the bike was warmed up? If you set it when cold, when it warms up it will idle faster.
    Make sure your throttle cable is lubed up and is returning properly. You may need to do some carb work if the cables are fine. For example if the carb slide is not moving well in the body. Both can cause delayed response after rev.
  3. skeeter
    skeeter Member
    Iron Mountain, MI
    mine idles at about 900 RPMs or so until it's fully warmed up - and it takes several miles to fully warm up.
  4. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    its been running fine up until today. ill check the cable to be sure its not that. thanks guys
  5. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    throttle cable works ok. what type of carb work ?
  6. skeeter
    skeeter Member
    Iron Mountain, MI
    possibly a dragging or sticking piston* (see "clunk test")
    *carb piston, not - you know, the internal combustion piston
    could also be- possibly- some dirt or debris has found it's way to the end of the idle adjustment screw - that would mimic raising the idle speed.
    a mis-routed cable might also be the culprit - on my seca, it's pretty easy to mis-route the cable whenever you remove and re-install the gas tank. i don't know if you have a maxim or a seca and if you've recently had the tank off for anything . . . but that could be it, too.
  7. yamaman
    yamaman Member
    Staten Island, NY
    if you put pods or mods requiring jetting and if the main jets were only changed - the stock pilot fuel jets could do this. they would also need to be increased
  8. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    thanks for the replys, gives me somewhere to start... 8)
