HELP!! Valve clearance confused
Discussion in 'XJ Technical Chat' started by Ground-Hugger, Apr 20, 2010.
  1. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    Ok I checked my valve clearances and they are all running about 0.075 MM.
    Do I need to change them :?:
  2. MiCarl
    You've got gauges that go to 1/1000th MM?????? Are you sure it's not 0.075" which is 0.19 MM?
    Intake clearance is 0.10 - 0.15 MM
    Exhaust clearance is 0.16 - 0.20 MM.
    If your measurement is correct you're way tight.
  3. bigfitz52
    It might help if we knew what bike.
    If it's an aircooled XJ, then the answer is yes. Big time.
    Specs:
    Intake: 0.11-0.15mm
    Exhaust: 0.16-0.20mm
  4. Ground-Hugger
    0.100MM, it does not even fit, to tight. It is a 1983 Maxim 750K. I am measuring 180 deg opposite the lobe on the cam and thats the measurement I get. And the intake and exhaust are about the same measurements.
  5. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    0.100 mm = .004"
    0.075 mm = .003"
    Intake cam spec is 0.11 - 0.15 (or .004" - .006")
    Exhaust cam spec is 0.16 - 0.20 (or .006" - .008")
    So, depending on your exact measurement, some of your intake valve shims might be okay but your exhaust valve shims need to be adjusted.
  6. Ground-Hugger
    OK Fraps I'll do a re check and order new shims. Thanks for the info.
  7. bigfitz52
    Use a metric feeler if possible-- .004 is NOT .11mm, it's .1016mm. The "Imperial" (American) equivalent clearances are actually out of spec at the extremes. If you read .004" it's tight...
  8. Ground-Hugger
    Fitz my measurements are approx 0.075 MM on ALL the valves a 0.105 MM gauge will no fit between the shim and the cam.
  9. bigfitz52
    Then they are all tight, as you surmised.
