don't know if its a step in the right direction
Discussion in 'XJ Technical Chat' started by lanthren, Apr 15, 2010.
  1. lanthren
    lanthren Member
    Caldwell Idaho
    ok, it all started when my 81 maxim 650 started over revving, tracked that down to a lean burn due to petcock problems, replaced the petcock with a good one that i had and tracked another lean burn to leaking intake boots, i'm hoping that once i get those fixed i can get her on the open road, any advice...oh, by the way, engine has an oil leak at the tach cable. how do i stop this as well
  2. shnuffy
    shnuffy Member
    Guelph, Ontario
    All I can say is check for rear brake shoe delamination. Search it!
  3. lanthren
    lanthren Member
    Caldwell Idaho
  4. bigfitz52
    You stop the tach cable leak by replacing the oil seal inside and the o-ring on the outside of the tach gear housing.
    Take a look: http://xjbikes.com/Forums/viewtopic/t=19538.html
    Very common, both my XJs started leaking pretty much as soon as they became operational again.
  5. lanthren
    lanthren Member
    Caldwell Idaho
    repaired the intake boots with an innertube, not sure if i did it right, do i use RTV then the inner tube or just the innertube.....i just used the innertube. anyways, still in a super lean condition even with mixture screws at 8 out, local yamaha shop wants to overhaul the carbs and charge over 400 in labor to do it, plus parts. i need some kind of help because as a college student i don't have the money to pay 400 in labor
  6. gitbox
    gitbox Member
    Maybe leaking throttle shaft seals?
    A TOTAL carb disassembly to replace those buggers.
  7. lanthren
    lanthren Member
    Caldwell Idaho
    crap, i was hoping something simpler
