broke a wire
Discussion in 'XJ Technical Chat' started by chadall3n, Apr 29, 2010.
  1. chadall3n
    chadall3n Member
    Clinton, MA
    Does anyone know what this wire does and where I could get a new one? I think it is some kind of sensor for the clutch? I had to take off the clutch handle off because I stripped The tightening bolt and had to rethread it. This wire must have been barely hanging on and fell out. It has very small crimps and I think it would be easier to just replace it. Thanks[​IMG][/img]
  2. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    I'm guessing you are talking about your clutch switch. It is part of the safety starting circuit that allows you to start the bike while in gear as long as the clutch is pulled in.
    I'm sure you can find one from Chacal or ebay.
  3. chacal
    Yep, that's the clutch hand lever position switch......we got them in stock!
  4. chadall3n
    chadall3n Member
    Clinton, MA
    how much do they run?
