Want to change speedometer face on '83 650 Maxim.
Discussion in 'XJ Modifications' started by Zyggy, May 11, 2010.
  1. Zyggy
    Zyggy Member
    Perry County, PA
    So I really like my bike, but I REALLY hate the speedometer. Not the gauges, just the face of the speedometer. It's the way the speedometer goes from 55 to 60 but everything above 60mph is in RED and in intervals of 10mph as to say "DANGER DANGER DANGER!"
    Does anyone know of replacement inserts for the speedometer on an 83 XJ650 Maxim??
  2. jeffdodge
    jeffdodge Member
    North East PA, USA
    I dont know of any off the top of my head, but I know gauge faces are EASY to make... All you need is photoshop skills and some light plastic type stuff to run thru your printer.
    I did some for my Ford Escort when I had it, but I used paper. Been thinking of doing my Maxim.
  3. jeffdodge
    jeffdodge Member
    North East PA, USA
    I can do a set for you if you would like after i test them on mine to make sure they work correctly when it is dark out.
  4. hogfiddles
    That would be a really good thing to do a write-up on, too.
    Dave
  5. jeffdodge
    jeffdodge Member
    North East PA, USA
    I may hop on mine, since I need to do fork seals before I go ride again.. In which case, I would do a walk through on it too.
    Ill go pull my gauges and take a look.
  6. KennyNapalm
    KennyNapalm Member
    Calgary AB
    Webslinger does custom speedos for a buncha bikes,
    http://www.stargis.net/webslinger/Image ... /index.htm
    tho, i do not know if they do any XJ, or XS bikes. last i checked tho, you can send him your speedo, and he will do it for you, and add it to his list of supported bikes,
    might be worth the email, and its not a bad price
    EDIT - from the site -
    "LOOKING FOR DONORS: If you don't see your motorcycle make or model listed here, it doesn't mean the speedometer can't be made. It just means that we don't have a speedometer to use as a template yet. In many cases a customer will take their speedo and send it to us and we can then make a speedo face using their stock dial as a template. That initial donor will receive their speedo face at no charge. E-mail us with questions."
  7. jeffdodge
    jeffdodge Member
    North East PA, USA
    UPDATE: Got the gauges apart, cant get the needle off. You might just try taking your speedo out and using flat black model paint and a fine tipped brush to take out the red...
    Im going to keep trying on this. Will give another update as soon as I can.
  8. Zyggy
    Zyggy Member
    Perry County, PA
    Okay, so I looked at my gauges and they are white in the area from 60mph and above, but nonetheless, the matter is the same.
    Jeff, if you figure out how to get that done, I would love to see a walkthrough. I can't remember if the insert is lit from underneath or from the bottom of the gauge. If it is from the underneath I would like to see how you get it to work at night.
  9. jeffdodge
    jeffdodge Member
    North East PA, USA
    Gave up for fear of breaking something. If I had a spare stock gauge laying around, I would give it hell and see if I could make headway, but I dont want to break the only speedo I have.
  10. Zyggy
    Zyggy Member
    Perry County, PA
    Understandable. My search continues!
  11. jeffdodge
    jeffdodge Member
    North East PA, USA
    I spoke with Webslinger last night, and Zyggy... Just send your gauges to the man.
    PM me and Ill give you his info. I was going to send mine and be the first set but you were the one looking for it, and I dont want to be without my instruments for two weeks.
    His turn around time is 3-5 business days, after you get it to him, so if your broke like me, its 3-5 for shipping, 3-5 for gauge work, 3-5 for shipping home. Thats between 9-15 days + weekends. I cant be without my gauges that long during riding season!
  12. Zyggy
    Zyggy Member
    Perry County, PA
    Awesome! Sorry for the delay in response, I forgot about this thread for a bit. It's been a long week at work. PM is sent!
