oil change and shaft change questions. I searched first
Discussion in 'XJ Technical Chat' started by BlackSpanker, May 12, 2010.
  1. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    as of today I am the proud owner of an 82 xj750. I was reading about the oil change and apparently there is second oil drain plug hidden near the shaft drive??? I looked all over and couldnt find it. Is there a pic anywhere? also how much gear oil am I supposed to put into the shaft drive? thanks
  2. iwingameover
    iwingameover Active Member
    Don't find the second middle gear plug. Chances are you'll shear it off.
    The shaft drive (diff) takes oil upto the fill hole. I don't know off the top of my head how much that is. If it runs out a bit it's full.
  3. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    thanks. you mean after the oil cycles in the diff it will no longer be up to the fill hole? Also I didnt change the filter and I put 2.5 quarts of oil in the engine. It was still low. I added half of a quart. Is this normal?
  4. skillet
    skillet Active Member
    SW TN
    Fill to the bottom of the threads for gear oil. Right next to the filler hole (for engine oil) is the exact amount (of course it's a metric measurement)...
    skillet
  5. iwingameover
    If I recall mine says 2,500cc's on a 650. That's 2.64 quarts.
